Loading...
Pages: 1 [2] 3 4 5   Go Down
Author Topic: DS18B20 multiple sensors  (Read 2217 times)
Offline Offline
Newbie
View Profile
Ok i have now tried with only one 4.7k resistor (between DATA and +5V wires), and it works with 11 sensors, with the same code used before. Now i will try it with at least 22 sensors, and we will see what happens smiley
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
At some point, it will stop working again.  If you have an oscilloscope, you can see how the signal degrades as you pile on sensors.  It's not like it's a very clean signal to start with.  Long cables will add to your woes because of the capacitance of the wiring.  Lower value pull-up resistors will help in many situations.  As you already saw, you could go as low as 1k if needed since it was working until you got it below about 500 ohms.  The sensors were only designed to sink 4mA which means even 1k is a little small.
Logged
Experience, it's what you get when you were expecting something else.
Offline Offline
Newbie
View Profile
Quote
Yes, i realize that, and when it does i will try with smaller resistor or something like that.
Is there any difference in number of sensors which can be connected or in code how to retrieve temperature if i would wire it like you (@afremont) said?
Quote
I suggest the OP read some Dallas documentation on powering the 1-wire data bus.  He could get rid of a wire (+5V) by using parasitic power mode thru the data line.  Then he'd only have to run the Data(Q) and Gnd wires to the sensors.  Handier sometimes.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
You're beyond me but could he use a circuit to drive a led as a line indicator?
Also, couldn't an Arduino support more than one 1-wire bus?
Logged
Examples can be found at Learning in the Main Site and at the Playground
texas
Offline Offline
God Member
old, but not dead
View Profile
Time to look at the datasheet, it tells all.  The only difference is that you have to supply extra power when a temp conversion (or EEPROM write) is in progress.  The datasheet shows how to do it, it's simple; it takes an extra i/o pin though.  You just enable the pin after issuing the conversion command.  That in turn bypasses the pull-up resistor on the data line (Q) so that the device has plenty of power to do the temp conversion or write to its EEPROM.  Look at the datasheet, they have a nice write-up on how it all works.
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
I'm not sure what you mean about the LED.  Do you mean as an indicator of activity?
Any pin could be another 1-wire bus, but I don't know if the library supports that or not.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Perhaps a difference in brightness would tell something useful about the power line (non-parasite) with X number sensors connected? It would vary as signals are sent but would anyone be able to see that as anything but light level?
If it could then he could tune his power line resistance with a pot.
Quote
If DS got the idea that they could sell more devices by supporting more pins, would it happen ASAP?
Logged
Offline Offline
Newbie
View Profile
Reporting smiley Successfuly connected 22 DS18B20 sensors and one DHT22. I used one 4.7k resistor for those 22 DS18B20 sensors and one 4.7k resistor for that one DHT22.
DHT22 sensor is wired like that:
http://api.ning.com/files/PKFE7DukclQO*V1lbgx2A1Xd*8ffMCvXqAA4Qd-*7J2cFd9DkoZyqDjdIURURatYsNTYNDLc77VSqOklXk-YnQmKI4l6dfie/RHT03arduino1.png
How can i wire multiple DHT22 sensors on Arduino Mega board? Becouse DHT22 data cable has to be each on its own pin, so therefore i have to use as many resistors as there are DHT22 sensors or is there any other way to wire it up? Becouse if that is so, i think there i'll have the same problem as i had with DS18B20 sensors.
« Last Edit: March 01, 2013, 06:02:05 pm by gasperinn » Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
There are parallel to serial shift registers. You can read a whole line of bits from the pins on chained shift registers (1 CS on the master to CS chip 1 chains to CS chip 2, etc) as SPI serial at 2 MHz. But, hardware SPI may use pins that 1-wire does so maybe use soft-SPI and 1 MHz speed.
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
The 1-wire stuff is only in software already, so you can pick any pin you want for it.
(gasperinn)   That's cool on the 22 connected.  How long is the bus physically?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
That says yes, hardware SPI can live with 1-wire. 2 buses can cross on a single chip.  smiley-grin
Quote
Quote
OP:
He can wire the DHT22's through a resistor each to the parallel-in side of 3 daisy-chained shift registers on an SPI bus and read, semi-process and store the states of all the DHT22's as bits at SPI speed, 2MB/sec. To read and store 24 bits through SPI would take only 24 cycles, 1.5 usec and you have all your DHT22 lines as digital states. If you do that 1000x a second, you have loads of time to copy the data to SPI between captures, 976 cycles out of 1000.
Logged
Offline Offline
Newbie
View Profile
@afremont, @GoForSmoke, i dont know, every sensor is physically cca. 15m away from the Arduino board, and it is wired with standard UTP network cable smiley
@GoForSmoke, i don't realy understand how do you meen, do you maybe have any shematic picture or something like that?  smiley-red
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Is that for parasite mode only?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Using SPI bus shift registers, it would connect like in the Daisy chain SPI configuration here:
The 3 SPI slaves would be 3 8-bit parallel to serial shift registers. A sensor would hook to each input pin which is not shown in the wikipedia diagram. The registers read the digital state from the sensor and on command, copies those as bits. Then the bits are shifted out of the chips and read by the master in as fast as 1.5 microseconds.
The register has its own power line, some people power leds off them on external power.
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
Yes it is.
Logged
Pages: 1 [2] 3 4 5   Go Up
Print
Jump to:
