Author Topic: L293d motor controller problems  (Read 320 times)
L293d motor controller problems.  I am trying to build a circuit using the L293d h-bridge. I need bidirectional control of two small dc motors. I have tried circuit after circuit from the internet, and the best I have done is to get control in one direction only.  Most of the circuit and programs I have tried had problems. My final goal is to use an  arduino nano with my homebuilt L293 chip. I was originally trying to get it to work with a Uno, but for some reason the serial com port kept changing and dropping out, which is another matter.  Right now Im trying to get it to work with a mega.  But for some reason, any of the programs.  The below code seems to only respond to:  digitalWrite(motor1Pin1, LOW);   // set pin 2 on L293D low
        digitalWrite(motor1Pin2, HIGH);  // set pin 7 on L293D high
I can't get the motors to reverse!
Does anyone have or know of a TESTED circuit diagram AND corresponding program that works, forward, and reverse.
I have spent many hours trying to get this to work.  Please don't suggest a bought motor shield, as I am working with students, and each student needs to pay for parts, and we need to keep the cost as low as possible,
Thanks for ANY help!
one of the programs include:
  // if the switch is high, motor will turn on one direction:
  if (digitalRead(switchPin) == HIGH) {
  // if the switch is low, motor will turn in the opposite direction:
  else {
    digitalWrite(motor1Pin1, HIGH);  // set pin 2 on L293D high
    digitalWrite(motor1Pin2, LOW);   // set pin 7 on L293D low
Seattle, WA USA
Seattle, WA USA
Code is useful AFTER you have a proper circuit. You haven't shown a circuit yet, so reviewing the code is premature.
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Try this, and make SURE everything is properly connected. Also post your full code.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Please excuse my ignorance, but Im very rusty in electronics, just getting back into after way to many years.
I have seen this circuit also. I know Im asking a lot but if I could see what pins go to which specific pins on the arduino, AND a program that works with that specific circuit configuration, It would be GREAT.
Thanks so much for your reply.
Queens, New York
You have to post your code so far. The problem might be the code and not with the circuit. Any two I/O pins will do, but pins labeled as PWM will allow you have control of the speed.
This is the last hookup and program I tried..  from  http://itp.nyu.edu/physcomp/Labs/DCMotorControl
But I also want to be able to change the motors (2) directions via program, not via discrete switch..
Thanks again  Wayne
const int switchPin = 2;    // switch input
const int motor1Pin = 3;    // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 4;    // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 9;    // H-bridge enable pin
    // set the switch as an input:
    pinMode(switchPin, INPUT);
    // set all the other pins you're using as outputs:
    pinMode(motor1Pin, OUTPUT);
    pinMode(motor2Pin, OUTPUT);
    pinMode(enablePin, OUTPUT);
   // pinMode(ledPin, OUTPUT);
    // set enablePin high so that motor can turn on:
    digitalWrite(enablePin, HIGH);
      digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low
      digitalWrite(motor2Pin, HIGH);  // set leg 2 of the H-bridge high
    // if the switch is low, motor will turn in the other direction:
    else {
      digitalWrite(motor1Pin, HIGH);  // set leg 1 of the H-bridge high
      digitalWrite(motor2Pin, LOW);   // set leg 2 of the H-bridge low
Queens, New York
Your code looks fine, so it is possible that your switchPin is in the wrong pin. Or, it could be your wiring is somehow wrong. Double check everything, and do a simple test. Get rid of the IF statement and just have the motor commands.
Isolate the problem.
Yep tried that..  got rid of the if statements in the following  lines of code
this seemed to work   digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low
but this didnt:      digitalWrite(motor1Pin, HIGH);  // set leg 1 of the H-bridge high
motor wouldnt run at all with the last two lines of code.
Queens, New York
Ok so if motorPin2 is HIGH, it runs and if motorPin1 is HIGH, it does not. Sounds to me like a wiring issue. Try this, bypass the arduino altogether(disconnect it) and just put a jumper to one of those input pin on the L293d. I think they already have pull down resistors inside, so by just putting one input HIGH, the motor should run depending on whichever input is high.
Make sure your motor pins are 3 and 4, and not 4 and 5.
« Last Edit: February 25, 2013, 03:31:32 pm by HazardsMind » Logged
