Topic: Smooth animation with an 8x8 RGB LED matrix (Read 46159 times) previous topic - next topic
Helmuth
#15
Oct 09, 2013, 09:01 am Last Edit: Oct 09, 2013, 01:36 pm by Helmuth Reason: 1
...mapped to a 240 LED Strip with WS2812 on a cylindrical matrix...
http://www.youtube.com/watch?v=y7jLOD_df7g&feature=player_embedded
Helmuth
Because many people asked here a quick solution how to map the whole matrix to a strip:
Code: [Select]
* Copyright (C) 2013 Gilad Dayagi.  All rights reserved.
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
  * An example for the Arduino particle system library
  * Creates a spinning galaxy effect
  * Note: this example uses the colorduino library becuse that is what I had,
  * but any device that supports setting a pixel to an RGB value can be used
//#include <Colorduino.h>
#include <FastSPI_LED2.h>
#include "ParticleSys.h"
#include "Particle_Bounce.h"
#include "Emitter_Spin.h"
#include "PartMatrix.h"
#define NUM_LEDS 240
CRGB leds[NUM_LEDS];
const byte numParticles = 600;
Particle_Bounce particles[numParticles];
Emitter_Spin emitter(112, 112, 5, 7);
ParticleSys pSys(numParticles, particles, &emitter);
PartMatrix pMatrix;
* Render the particles into a low-resolution matrix
void drawMatrix(){
    pMatrix.fade();
    pMatrix.render(particles, numParticles);
    //update the actual LED matrix
   for (byte y=0;y<8;y++) {
        for(byte x=0;x<8;x++) {
            //Colorduino.SetPixel(x, y, pMatrix.matrix[x][y].r, pMatrix.matrix[x][y].g, pMatrix.matrix[x][y].b);
    leds[40+(x*2)+y*20].r = pMatrix.matrix[x][y].r;
    leds[41+(x*2)+y*20].r = pMatrix.matrix[x][y].r;
    leds[40+(x*2)+y*20].g = pMatrix.matrix[x][y].g;
    leds[41+(x*2)+y*20].g = pMatrix.matrix[x][y].g;
    leds[40+(x*2)+y*20].b = pMatrix.matrix[x][y].b;
    leds[41+(x*2)+y*20].b = pMatrix.matrix[x][y].b;
  //Colorduino.Init(); // initialize the board
  FastLED.addLeds<WS2812, 6, GRB>(leds, NUM_LEDS);
  // compensate for relative intensity differences in R/G/B brightness
  // array of 6-bit base values for RGB (0~63)
  // whiteBalVal[0]=red
  // whiteBalVal[1]=green
  // whiteBalVal[2]=blue
  byte whiteBalVal[3] = {36,63,7}; // for LEDSEE 6x6cm round matrix
  //Colorduino.SetWhiteBal(whiteBalVal);
  randomSeed(analogRead(0));
  pMatrix.reset();
  //Colorduino.FlipPage(); // swap screen buffers to show it
  emitter.oscilate = true;
    pSys.update();
    drawMatrix();
    FastSPI_LED.show();
    delay(5);
electroGUS
would like to know if someone successfully ported the led matrix code to the led strip hardware.
im working on it , but it seams that in not only a conversion of coordinates and also adapting to use the led strip functions, but it seams that the libraries itself needs to be modified .
As i still don't think this make sense, im inclined to think , that a better knowledge of how to modify the fountain generation parameters , for a certain led pattern is what is needed.
Then my question, is if somebody have any documentation on the libraries.
thanks
gus
janvier123
electroGUS
anybody knows how to modify the code in order to include a wider matrix?
I have tried by changing the y range to 30 , but this doesn't work .
 * A wandering particle that emits colorful smoke
//'r' for rainbowduino, 'c' for colorduino
//#define BOARD 'r'
//#if BOARD == 'c'
//#else
//#include <Rainbowduino.h>
//#endif
#include "FastLED.h"
#include "Particle_Std.h"
#include "Particle_Fixed.h"
#include "Emitter_Fountain.h"
const byte numParticles = 40;
boolean pulseOn = false;
Particle_Std particles[numParticles];
Particle_Fixed source;
Emitter_Fountain emitter(0, 1, 10, &source);
PartMatrix pMatrix;
#define NUM_LEDS 237
void drawMatrix(){
    pMatrix.reset();
    int LEDnum ;
//#if BOARD == 'c'
//            Colorduino.SetPixel(x, y, pMatrix.matrix
  • [y].r, pMatrix.matrix
  • [y].g, pMatrix.matrix
  • [y].b);
//#else
//            Rb.setPixelXY(PS_PIXELS_Y-y-1, x, pMatrix.matrix
  • [y].b);
//#endif
  if ((y & 01) == 0) {
    LEDnum = (y+1)*30 - x-1;
    LEDnum=y*30+x;
    leds[LEDnum].r = pMatrix.matrix
  • [y].r;
    leds[LEDnum].g = pMatrix.matrix
  • [y].g;
    leds[LEDnum].b = pMatrix.matrix
  • [y].b;
//#if BOARD == 'c'
   // Colorduino.Init(); // initialize the board
     FastLED.addLeds<WS2812B, 6, GRB>(leds, NUM_LEDS);
//#else
  //  Rb.init();
//#endif
    //source.vx = 3;
    //source.vy = 1;
    source.x = 0;
    source.y = 1;
    Emitter_Fountain::minLife = 20;
    Emitter_Fountain::maxLife = 80;
    Particle_Std::ay = 1;
    //PartMatrix::isOverflow = false;
    //init all pixels to zero
    pMatrix.reset();
    pSys.update();
    drawMatrix();
//#if BOARD == 'c'
     FastLED.show();
//#endif
    delay(40);
gus
robtillaart
these are the important lines.
Code: [Select]
And please modify your post and put the code between [code]...[/code] tags
it is now unreadable
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
DangerouslyExplosive
This looks really cool. I have a matrix I built myself (10x8) that I run off of a Mega. Any chance there's a way to change the code to work with that?
I really want to do stuff like this on my setup, but I can only find codes for dedicated controllers or the Teensy boards, nothing that will work on the Mega. I'm not that great at coding, so there's almost no chance that I will ever be able to write a whole new program myself, and I have no budget to go out and get new hardware. Any help would be appreciated.
