Topic: electric door strike help (Read 2731 times) previous topic - next topic
dimona
i am try to connect the electric door strike to Arduino and i d'ont know how to start.
how i connect him?
what the code to open and close?
this what i have :
alot of tnx!
PeterH
Find the spec for the door strike. Understand what the electrical characteristics are. Design a circuit capable of driving the electrics which can be controlled by TTL levels. Build that circuit and connect it to the Arduino. Write a sketch that provides the appropriate TTL output signals to make your driver circuit operate the device. Design the rest of the sketch to implement whatever control algorithm you want. Presumably you'll have some form of inputs to determine when to operate the door strike; you'll need to carry out a similar exercise to interface the Arduino with those.
I only provide help via the forum - please do not contact me for private consultancy.
dimona
this what i do, what wrong?
the transistor is 2N222A
JimboZA
According to that pic, you have the load on the transistor's base,
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
dimona
what i need to do  :smiley-sad-blue: ?
JimboZA
Have a look at this tutorial. And look at a data sheet for your transistor to make sure you understand which pin is which.
You'll need to get a diode as well.....
AWOL
Your mechanism should be driven exactly as you would drive a heavy-duty relay. I think a 2N2222 might be a little lightweight.
If that's all you've got for a transistor, it may be simpler to use it to drive a relay, and drive the strike from the relay's contacts.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
PeterH
Once you have sorted out the hardware side, you need to get the sketch to compile - which it won't currently.
dimona
you can give my the code? I'm really desperate I want to continue with the project even online I found something similar to what I'm trying to do
PeterH
There's really no point trying to move forwards on the code until you have got the hardware right, and then the next step will be to get your code to compile. Which it currently won't, for reasons which should become obvious when you try.
dimona
#10
Mar 03, 2013, 08:00 pm Last Edit: Mar 03, 2013, 08:01 pm by dimona Reason: 1
i connect like this :
Uploaded with ImageShack.us
pdf of ULN2803A:
http://www.alldatasheet.com/datasheet-pdf/pdf/169423/ETC2/UNL2803.html
now the lock get power but still the software code not work!
Code: [Select]
  //Start serial
  pinMode(13,OUTPUT);
   digitalWrite(13,255);
Can someone direct me?
AWOL
Code: [Select]
what do you expect that to do, other than leave the pin HIGH?
dimona
AWOL
255 is the same as HIGH, as far as digitalWrite is concerned.
Why write it twice?
Erdin
I think the ULN2803 is already broken, perhaps the Arduino is also damaged.
You have to rewire the connections to the ULN2803. The chip doesn't use a positive voltage, but pin 10 is for the flyback diodes. The pin 10 shoud be connected the + side of the motor (and both should be connected to the (+) of the 9V battery).
The ULN2803 does need a ground. That ground should be connected to the Arduino GND and the (-) of the 9V battery.
Next you have to connect the input and output of the ULN2803 in the right way.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
