Loading...
Pages: [1]   Go Down
Author Topic: Relay to close 120volt contact triggered by ground  (Read 207 times)
Offline Offline
Newbie
View Profile
Hi, can anyone help me figure out a way to turn on my porch light, that will be triggered by a ground. So when I ground, the light comes on, when I unground, it goes off.
Thanks!
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
You want to use a relay.
Wire up the relay through a transistor to the arduino.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Who or what will be doing the grounding?
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Newbie
View Profile
Its my ip cameras external outputs, i know not arduino related, but you guys are smart. Ill house the relay in the light, where ill also have a 12 volt connection if that helps
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
In that case, it would help to know the specification of the IP camera output. As you are talking about "grounding", I presume it is an open-collector or open-drain output; but it may or may not be rated at +12V.
Logged
Offline Offline
Newbie
View Profile
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
It's an open-collector output, and it looks like it's designed to drive a relay already, without using an external transistor. So connect the coil of a 12V relay between the output and the +12V supply, and connect a flyback diode in parallel with the relay coil.
If you look on page 145 of the manual, it should tell you the current sink capacity of that output.
Logged
Pages: [1]   Go Up
Print
Jump to:
