« on: February 26, 2013, 02:38:46 pm » |
Hello, i have a ultrasonic sensor from maxbotix (mb7060) which output delivers asynchronous serial with an RS232 format, except voltages are 0-Vcc. The output is an ASCII capital “R”, followed by three ASCII character digits representing the range in centimeters up to a maximum of 765, followed by a carriage return (ASCII 13). The baud rate is 9600, 8 bits, no parity, with one stop bit. Because of RS232 format with TTL level (5 volts its a '0' and 0 volts its a '1') i have to put an TTL inverter to invert this voltages to arduino to understand it when it receives the readings on RX pin. At this time, everything works great, but when i power off the circuit (inverter and sensor) and look at serial monitor of arduino it keeps reading zeros and sometimes 1 or 3! My code is #include <SPI.h> #include <VirtualWire.h>
//DECLARAÇÃO DAS VARIÁVEIS GLOBAIS //ENABLE/DISABLE PARA O SENSOR const int sensor = 7;
//LED'S const int ledTransmissao = 4; const int ledActivacao = 5;
//ENABLE/DISABLE DO TRANSMISSOR E PINO DE TRANSMISSÃO const int pinoTransmissao = 8; const int pinoActTransm = 3;
//VARIÁVEL QUE GUARDA A MENSAGEM A TRANSMITIR char mensagem[5];
//VARIÁVEIS PARA DADOS LIDOS DO SENSOR int dados; char buffer[4];
void setup(){ //DEFINIÇÃO DOS PINOS DE ENTRADA E DE SAÍDA pinMode(sensor, OUTPUT); pinMode(ledTransmissao, OUTPUT); pinMode(ledActivacao, OUTPUT); digitalWrite(sensor, LOW); //digitalWrite(pinoActTransm, LOW); digitalWrite(ledTransmissao, LOW); digitalWrite(ledActivacao, LOW); //INICIAR A UART PARA DEBUG Serial.begin(9600); delay(100); //CONFIGURAÇÃO DO VIRTUALWIRE -TRANSMISSÃO- vw_set_tx_pin(pinoTransmissao); vw_set_ptt_pin(pinoActTransm); vw_setup(2000); //VELOCIDADE DE TRANSMISSÃO DE 2000 BITS POR SEGUNDO }
void loop() { //ENABLE DO SENSOR E LED DE ACTIVAÇÃO LIGADO digitalWrite(sensor, HIGH); digitalWrite(ledActivacao, HIGH); delay(100); //LEITURA DOS DADOS ENVIADOS PELO SENSOR if ( Serial.available () > 0 ) { char c = Serial.read(); if (c == 'R') { Serial.readBytesUntil ('\r', &buffer[0], 4); //mensagem = buffer; //GUARDA DADOS RECEBIDOS DO SENSOR -ASCII--RXXX\R-- //DISABLE DO SENSOR E LED DE ACTIVAÇÃO DESLIGADO digitalWrite(sensor, LOW); digitalWrite(ledActivacao, LOW); dados = atoi (buffer); //CONVERSÃO DOS DADOS RECEBIDOS PARA VALORES INTEIROS Serial.print("BUFFER: "); Serial.println(buffer);
//ENVIO PARA A SÉRIE DO VALOR, PARA DEPURAÇÃO Serial.print("Valor recebido:"); Serial.println(dados); memset(&buffer, 0, sizeof(buffer)); //LIMPEZA DO BUFFER Serial.print("Limpar buffer:"); Serial.print(buffer); Serial.println("Em branco depois dos : SUCESSO!!!"); /*VERIFICAÇÃO SE OS DADOS RECEBIDOS DO SENSOR SÃO VÁLIDOS. O MÁXIMO VALOR É 465 -ALTURA MÁXIMA DA ÁGUA- E O MÍNIMO É ZERO -TANQUE VAZIO-*/ if(dados >= 1 && dados <= 465) { mensagem[0] = 'R'; itoa (dados, &mensagem[1], 10); Serial.print("Mensagem a transmitir:"); Serial.println(mensagem); //LED DE TRANSMISSÃO ACTIVA LIGADO digitalWrite(ledTransmissao, HIGH);
//ENVIO DA MENSAGEM 2 VEZES PARA GARANTIR QUE É RECEBIDA //for (int i = 0; i<2; i++){ vw_send ((uint8_t*)mensagem, strlen(mensagem)); //ENVIO DA MENSAGEM vw_wait_tx(); //ESPERA QUE MENSAGEM SEJA TOTALMENTE ENVIADA delay(1); } //LED DE TRANSMISSÃO ACTIVA DESLIGADO digitalWrite(ledTransmissao, LOW); memset(&mensagem, 0, sizeof(mensagem)); //LIMPA O BUFFER DA MENSAGEM ENVIADA Serial.print("Limpar mensagem:"); Serial.print(mensagem); Serial.println("Em branco depois dos : SUCESSO!!!"); delay(5000); } } } //}
/*FIM DO PROGRAMA*/ I'm trying to get the values from reading, see if they are between 1 and 465 (the minimum and maximum distance i want) and then send by RF 433MHz to another arduino, that can't get any message because i thing something is making conflict with readings (like when sensor and inverter are powered off it should stay "paused" in serial monitor and not keep telling me it is reading like R0 or R1, R3 ?!? Thanks for any help with this problem
« Last Edit: February 27, 2013, 05:55:56 pm by blastboot »
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #1 on: February 26, 2013, 02:46:38 pm » |
It sounds like a floating input to me.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
« Reply #2 on: February 26, 2013, 02:57:46 pm » |
Can you explain a little more?
East Anglia (UK)
May all of your blinks be without delay
« Reply #3 on: February 26, 2013, 03:12:32 pm » |
An input that is not tied to a specific voltage, usually ground or 5V, may pick up stray voltages and is said to be 'floating'
Queens, New York
« Reply #4 on: February 26, 2013, 03:16:09 pm » |
You turn off the sensor and inverter, and you get weird numbers. That is to be expected when the pin is essentially open. Your inverter is off but the pin is looking for any possible electrical activity. This is usually noise or outside EMF, and the only way to stop it, would be to let the arduino know the inverter is off. Now you wont be able to actually pause the readings unless you change your program to have a timer or look for the inverter to be off. However you can avoid numbers like 3 or 9 etc. with a pull down resistor. This pull down resistor will make the output read "R0" until the inverter tells it otherwise.
For the timer, if you want to use it. You can look at the incoming data from the inverter and if the data does NOT change after a certain time has passed, you can set the output to 0. This timer can also, (if coded correctly) can "pause" your readings and output nothing at all, or display your readings when a signal is found.
« Reply #5 on: February 26, 2013, 03:43:01 pm » |
But i expected as i have in my program that only data started with an capital R must be looked at, and avoid any other data that could get in. if inverter and sensor are powered off any data that arduino can receive in RX pin must be all of thet you've said before. It's strange as it must be an R to arduino look at it. Am i right?
Left Coast, CA (USA)
Measurement changes behavior
« Reply #6 on: February 26, 2013, 03:47:11 pm » |
I too think an external resistor is a possible answer, however I think it should be of the pull-up variety as that is the idle/stopped state of a TTL serial data stream.
Lefty
Queens, New York
« Reply #7 on: February 26, 2013, 03:48:42 pm » |
When the power to the inverter is off, you have nothing to clear or reset "c" back to NULL. So Rxxx will stay inside the buffer until new data is available, to overwrite it.
« Reply #8 on: February 26, 2013, 03:55:54 pm » |
When the power to the inverter is off, you have nothing to clear or reset "c" back to NULL. So Rxxx will stay inside the buffer until new data is available, to overwrite it. but, memset(&buffer, 0, sizeof(buffer)); makes buffer cleared isn't it? (just trying to understand this  )
Queens, New York
« Reply #9 on: February 26, 2013, 03:58:23 pm » |
Well when in doubt, debug! Use the serial monitor to see exactly what your getting, and im sure you will find your answer.
« Reply #10 on: February 26, 2013, 04:04:46 pm » |
Yes, i've degub it, and keep getting readings of R0 and sometimes R1 or R3 with inverter and sensor powered off, and i'm trying to understand why, if my code only look at serial input starting with an 'R'. And i'm thinking if this can messed up with readings when sensor and inverter are working, because i'm trying to use virtualwires to send this value to another arduino by RF 433MHz, but i couldn't get any message received... Thanks for being helping me
« Reply #11 on: February 26, 2013, 05:18:50 pm » |
Could a pull-up resistor be a solution to this? Or maybe i can add something to my code to prevent it (I think serial data waiting state is 5v isn't it?)
« Reply #12 on: February 26, 2013, 05:30:52 pm » |
Isn't that what I stated in reply #6? Lefty
« Reply #13 on: February 26, 2013, 05:46:07 pm » |
Ok that is something i will test tomorrow. So at program level there's nothing that i could do (because current consumption minimize if i use the pull-up resister solution).
« Reply #14 on: February 27, 2013, 03:51:50 pm » |
I've tested the pull-up resistor today and it worked. With inverter and sensor powered off it just stops getting data (as expected). I've experienced another problem with my circuit as it sometimes, with everything working (powered on), reads strange values like some strange character, sometimes RRR or 70R ?!? Can you check my code on the first post and check if i'm doing something wrong? Today i've tried many other possibilities and changed some parts of the code (essencially the serial read part) and keeps getting this issue sometimes and it is an intermittent issue.
