Loading...
Pages: [1]   Go Down
Author Topic: COM Port Communication with VB  (Read 830 times)
Magdeburg
Offline Offline
Newbie
View Profile
Hey Guys,
i'm working for a few hours at the communication between my PC and a Leonardo, but I have a big problem to send data from Arduino to the PC. At first I thought I did a mistake at the serial-read or event function in visual basic. But now I figured out, that the Arduino doesn't send data, if I activate the com-port from my VB-program. However, if I use the standard Arduino serial monitor, I get sent data and the TX LED is blinking. If I'm using my VB script, I can't get a blinking LED, however, the communication in the other direction works well. For example I can send data to the Arduino and the RX LED blinks.
Now the question: Is there any function, I have activate to get the Arduino in a sending mode. I could imagine, It could something have to do with “handshaking”???
Thanks for the help.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The Leonardo requires that the DtrEnable flag be true. Are you setting it?
Logged
Magdeburg
Offline Offline
Newbie
View Profile
No!
I'll test it in the evening.
Thank you.
Logged
Magdeburg
Offline Offline
Newbie
View Profile
works perfectly,
mille grazie!
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
For future reference, perhaps you could post your VB code for opening the port.
Logged
Offline Offline
Newbie
View Profile
If I try to use a Terminal program with an Arduino Uno (R3 SMD) under windows 7, I get the message: "The port is not available".
However, when I use the Monitor Serial, I don't get the error and all the data flow fine, so nothing is locking the port....is this the same issue?
Thank you
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No.
Quote
You aren't trying to use the Terminal program at the same time as the Serial Monitor, are you? Have you closed the IDE?
Logged
Offline Offline
Newbie
View Profile
Quote
No.
Quote
Yes, of course I have tried to connect via Terminal after closing the IDE.
It happens the same to me, when using the programming port with the Arduino Due, I can only connect to the Native USB.
What is it then?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
That would be logical. The programming port is for, well, programming the Arduino. You aren't programming the Arduino from the Terminal application, are you?
Logged
Offline Offline
Newbie
View Profile
Quote
I am not, but wouldn't I be able to communicate to Arduino Uno via Serial.print() and Serial.read() commands?
I don't understand why the port is not available when I try to open it from another program different from Serial Monitor (which is supposed to be the same).
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Just from looking at other code, the leonardo has some special requirements as to its serial port. probably nothing to do with the comport issue on your pc, but there is something different. If you are using windows, have you looked in device manager at the comport settings for different comports and such?
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The only difference is that DtrEnable must be set to true.
Logged
Pages: [1]   Go Up
Print
Jump to:
