Topic: GOTO is back (Read 9381 times) previous topic - next topic
graynomad
At last we can use GOTO again without being vilified :)
The new MISRA standard now allows it's use (with caveats), I haven't seen the standard yet but here's a excerpt from an article on the Electronic Design site (http://electronicdesign.com/dev-tools/misra-c2012-plenty-good-reasons-change?NL=ED-07&Issue=ED-07_20130226_ED-07_678&YM_RID=rob@robgray.com&YM_MID=1375780&sfvc4enews=42)
Quote
Not All Goto Statements Patch Up Wooly Thinking!
All too often, goto statements are used to patch up wooly thinking or an ill-defined algorithm. However, there are situations where the use of the goto statement is justified. For example, if there is an emergency situation in a process-control application, is it really better to set a flag and check it later in the algorithm than to take a direct route via a goto?  The "goto statement should not be used" rule is now advisory rather than required, and an additional two rules narrow down the circumstances under which it is acceptable:
    The goto statement shall jump to a label declared later in the same function.
    Any label referenced by a goto statement shall be declared in the same block, or in any block enclosing the goto statement.
So all us wooly thinkers are off the hook now :)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
rockwallaby
Nooooooooooo, yee shall not pass goto, for if thou do'eth thou surely be cast into thee depths of eternity, lost and abandoned it time, never to return.
Paul - VK7KPA
nickgammon
Quote
So, you can't use it for loops.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
graynomad
Yeah, it looks like you can only jump forward.
Rockwallaby, I'll have what you're having :)
______
Rob
robtillaart
in case of an emergency you can use goto but you must not expect the system in a defined state thereafter. Even a graceful degradation is doubtful at best.
If you detect a real emergency (the "Houston we got a problem" kind) why not call the emergencyHandler() ?
And return afterwards and continue?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
JimboZA
Quote
If you detect a real emergency...
... who you gonna call? ghostBusters()
But if you have a huuuuge @#$%up, call Todd() ....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
robtillaart
Rob Tillaart
JoeN
GOTO "never left the building" for assembly language programmers.
I will never ask you to do anything that I wouldn't do myself.
nickgammon
If you use GOTO, I think you are going to end up calling Todd (see graphic above).
Palliser
Will spaghetti be served again?  :smiley-eek-blue:
graynomad
Quote
call Todd
I saw that sign recently on one of those "funny photos" sites, under the heading "Meanwhile in Aus" or some such. It's a classic.
______
Rob
rvasque
+1. Goto, Jump, Branch...
JimboZA
Quote
Well you guys do have a certain "way" with words, let's face it...
cr0sh
I involved myself in this conversation way-back-when on the electro-tech forum, regarding state machines:
http://www.electro-tech-online.com/general-electronics-chat/113718-state-machine-mcu.html
In it, me and another user (MikeMI) have a discussion regarding state machines and whether using IF-THEN logic and GOTOs for such implementations (vs a switch-case construct) is better, worse, or...?
Anyhow - he posted an image of an implementation of such a state machine:
http://www.electro-tech-online.com/attachments/general-electronics-chat/48665d1291323569-state-machine-mcu-elevator.png
(you'll need a login to see it) - or check it out here, rehosted: http://i.imgur.com/JkND1Av.png
Anyhow - I found that example of using IF-THEN logic and GOTO to implement such logic to be very interesting; it wasn't difficult to follow, and made me appreciate GOTO a bit more (I grew up on Microsoft BASIC on a TRS-80 Color Computer - GOTO was in my blood for a long time, until it was excised during my first professional software development gig).
I now think of it as one of those tools that one should be aware of, but should only use when the situation absolutely warrants it - breaking out of deeply nested logic is one potential area (provided you don't break a stack or something); though I would perhaps do some investigation into that logic to see if maybe there is some way to make it more workable without requiring such a sledgehammer measure.
...and a second potential situation would be this example of a state machine.
I have also seen an instance (when I worked at a place that used a variant of COBOL called DB/C) where GOTO was used to jump out of (or into? it's been so long now) an error "trap" routine; but the developers there who worked in that system (I was only peripherally involved) made it explicit that such use was the -only- place that GOTO was allowed in the software they developed, and no where else.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
JimboZA
Quote
Like using water-pump-pliers to undo a nut....
