Pages: [1] 2   Go Down
Author Topic: GOTO is back  (Read 646 times)
nr Bundaberg, Australia
At last we can use GOTO again without being vilified smiley
The new MISRA standard now allows it's use (with caveats), I haven't seen the standard yet but here's a excerpt from an article on the Electronic Design site (http://electronicdesign.com/dev-tools/misra-c2012-plenty-good-reasons-change?NL=ED-07&Issue=ED-07_20130226_ED-07_678&YM_RID=rob@robgray.com&YM_MID=1375780&sfvc4enews=42)
Not All Goto Statements Patch Up Wooly Thinking!
All too often, goto statements are used to patch up wooly thinking or an ill-defined algorithm. However, there are situations where the use of the goto statement is justified. For example, if there is an emergency situation in a process-control application, is it really better to set a flag and check it later in the algorithm than to take a direct route via a goto?  The “goto statement should not be used” rule is now advisory rather than required, and an additional two rules narrow down the circumstances under which it is acceptable:
    The goto statement shall jump to a label declared later in the same function.
    Any label referenced by a goto statement shall be declared in the same block, or in any block enclosing the goto statement.
So all us wooly thinkers are off the hook now smiley
______
Rob
Tasmania - Australia
Nooooooooooo, yee shall not pass goto, for if thou do'eth thou surely be cast into thee depths of eternity, lost and abandoned it time, never to return.
Renewable Energy Monitor Project http://paulalting.com/hydrosolar.php     No, I don't really suffer from insanity, I enjoy it.     I do it with Eclipse IDE and Jantje's AVR plugin http://baeyens.it/eclipse/
Melbourne, Australia
Shannon Member
Lua rocks!
So, you can't use it for loops.
Yeah, it looks like you can only jump forward.
Rockwallaby, I'll have what you're having smiley
______
Rob
Netherlands
in case of an emergency you can use goto but you must not expect the system in a defined state thereafter. Even a graceful degradation is doubtful at best.
If you detect a real emergency (the "Houston we got a problem" kind) why not call the emergencyHandler() ?
And return afterwards and continue?
Rob Tillaart
Johannesburg UTC+2
If you detect a real emergency...
... who you gonna call? ghostBusters()
But if you have a huuuuge @#$%up, call Todd() ....
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Netherlands
LOL !
Rob Tillaart
Samplefinger
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
GOTO "never left the building" for assembly language programmers.
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Shannon Member
Lua rocks!
If you use GOTO, I think you are going to end up calling Todd (see graphic above).
Venezuela
Ground.......ground........always ground
Will spaghetti be served again?  smiley-eek-blue
call Todd
I saw that sign recently on one of those "funny photos" sites, under the heading "Meanwhile in Aus" or some such. It's a classic.
______
Rob
+1. Goto, Jump, Branch...
Johannesburg UTC+2
Well you guys do have a certain "way" with words, let's face it...
IT Crowd:
Phoenix, Arizona USA
Where's the beer?
I involved myself in this conversation way-back-when on the electro-tech forum, regarding state machines:
http://www.electro-tech-online.com/general-electronics-chat/113718-state-machine-mcu.html
In it, me and another user (MikeMI) have a discussion regarding state machines and whether using IF-THEN logic and GOTOs for such implementations (vs a switch-case construct) is better, worse, or...?
Anyhow - he posted an image of an implementation of such a state machine:
http://www.electro-tech-online.com/attachments/general-electronics-chat/48665d1291323569-state-machine-mcu-elevator.png
(you'll need a login to see it) - or check it out here, rehosted: http://i.imgur.com/JkND1Av.png
Anyhow - I found that example of using IF-THEN logic and GOTO to implement such logic to be very interesting; it wasn't difficult to follow, and made me appreciate GOTO a bit more (I grew up on Microsoft BASIC on a TRS-80 Color Computer - GOTO was in my blood for a long time, until it was excised during my first professional software development gig).
I now think of it as one of those tools that one should be aware of, but should only use when the situation absolutely warrants it - breaking out of deeply nested logic is one potential area (provided you don't break a stack or something); though I would perhaps do some investigation into that logic to see if maybe there is some way to make it more workable without requiring such a sledgehammer measure.
...and a second potential situation would be this example of a state machine.
I have also seen an instance (when I worked at a place that used a variant of COBOL called DB/C) where GOTO was used to jump out of (or into? it's been so long now) an error "trap" routine; but the developers there who worked in that system (I was only peripherally involved) made it explicit that such use was the -only- place that GOTO was allowed in the software they developed, and no where else.
Johannesburg UTC+2
Like using water-pump-pliers to undo a nut....
IT Crowd:
Pages: [1] 2   Go Up
