Topic: Problem getting state and toggling output pin on Arduino Due (Read 2151 times) previous topic - next topic
Euhenio
Feb 27, 2013, 02:21 am Last Edit: Feb 27, 2013, 02:34 am by Euhenio Reason: 1
I have got a problem with toggling and getting current state of the output pin on Arduino Due and Arduino 1.5.2 software.
The pin stays high all the time and digitalRead(pinnum) always returns 0.
Tried with this code and some variations of it.
Code: [Select]
int pinnum = 13;
 pinMode(pinnum, OUTPUT);  // use on-board LED
 digitalWrite(pinnum, !digitalRead(pinnum));
 delay(1000);  // wait around for 1 sec (1000 ms)
I would appreciate help very much.
Euhenio
What is the problem?
The pin stays high all the time and digitalRead(pinnum) always returns 0. The code I've posted earlier doesn't blink led.
Sorry, forgot to describe the problem in first post. Edited.
nickgammon
On the Due, possibly reading an output pin may always return 0. After all, reading from output is not necessarily defined.
I'm moving this to the Due section of the forum.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Euhenio
Is there any work around for this? Or determining current state of output pin is not really possible on Due?
nickgammon
Make your own function, that when you do a digitalWrite, it remembers what you set it to.
I personally think, that when you set something as "output" it isn't all that valid to read from it. It's your job to remember what you last wrote.
Euhenio
Ok, I got the idea. Thanks for help.
