Offline
Newbie
« on: February 27, 2013, 03:38:42 am » |
Hi, I'm stuck with my problem and I need guys your help to think along. Currently I want to build shaft counter and there is some requirements which I have to follow like I can only put on hose clamp ( http://www.cn-parts.ee/pood/17776-9754-thickbox/vooliku-klamber-20-35mm.jpg) on shaft. Because big items can fly away from shaft or causing vibration which is not allowed. Shaft can have a maximum spindle speed of 1000 rpm which is quite fast. So what could be the best solution for 0 to 1000 rpm sensor counter for this solution. For using some optical sensors or DC motor frequency? Or enything else?
Logged
Offline
Full Member
« Reply #1 on: February 27, 2013, 03:41:31 am » |
i have no idea if this is practical for 1000rpm, but maybe take a look at how speed is measured with a bikecomputer and a magnet inducing a pulse or with some sort of reed switch
« Last Edit: February 27, 2013, 03:44:43 am by lax123 »
Logged
Offline
God Member
« Reply #2 on: February 27, 2013, 05:07:49 am » |
1000 rpm really isn't all that fast. Small electric motors routinely run well over 10000 rpm these days
Logged
Offline
Newbie
« Reply #3 on: February 27, 2013, 06:38:21 am » |
I forgot to add that distance of shaft and it's connector frame can be 1cm to 20cm. So in some situations magnetic (hall) can not be used for example 10cm distances.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #4 on: February 27, 2013, 06:51:39 am » |
Attach a mirror to it and bounce a laser beam into a phototransistor.
Logged
Portugal
Online
God Member
Tomorrow I will know a BIT more than yesterday
« Reply #5 on: February 27, 2013, 07:18:51 am » |
You could also put a little screw in the shaft and then using a capacitive sensor near to it.When it rotate pass in front of the sensor and generate an impulse.Then you can attach that signal(must insure voltage level compatible ) to a timer inside arduino, with an interrupt on falling edge.
Logged
Debian,Mint,Ubuntu Arduino Mega 2560 Arduino Nano Arduino Duemilanove MAC OS Montain Lion Raspberry PI Model B
texas
Offline
God Member
old, but not dead
« Reply #6 on: February 27, 2013, 09:19:23 am » |
Since balance is an issue, use a piece of black tape with a white spot on it and an optical sensor.
Logged
Experience, it's what you get when you were expecting something else.
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #7 on: February 27, 2013, 10:15:00 am » |
Why bother with the tape... Paint the whole disk black and then put as many spots as you need for accuracy...
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Valencia, Spain
Offline
Edison Member
« Reply #8 on: February 27, 2013, 10:35:00 am » |
Yep. Tape can come off. What would you use as a sensor?
Logged
Lindenwold, NJ USA
Offline
Newbie
« Reply #9 on: February 27, 2013, 11:52:18 pm » |
Look into rotary encoders. Optical is the best, but may be pricy. You can even determine direction, if needed.
Logged
+++++++++++++++++++++++++++++++++++++ The completion date of a software project is 2 weeks from any given date.
