Loading...
Pages: [1]   Go Down
Author Topic: Linux: 2 duemilenova's. standard user only One works; root both work  (Read 154 times)
Offline Offline
Newbie
View Profile
Hi
I have 2 duemilenova's attached to my Linux redhat enterprise edition 6.
When I start the Arduino IDE (I tried 1.03; 1.5.2 and 1.5.3 all behave the same) as standard user (jan) I only see 1 usb port. I verified and it is always the same Arduino that works.
I tried the "bad Arduino" on windows xp where I had no issues.
I tried as root and both Arduino's work fine.
I'm new to Linux and a desktop platform but my bet is that there is some configuration issue.
I've tried what I could find but I still have no clue what could be wrong.
All commands below have been executed as jan (so not root).
After disconnecting and reconnecting I see the following in dmesg
Code:
bash-4.1$ dmesg | tail -30
ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
ftdi_sio 1-1.1:1.0: device disconnected
usb 1-1.1: new full speed USB device number 14 using ehci_hcd
usb 1-1.1: New USB device found, idVendor=0403, idProduct=6001
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: FT232R USB UART
usb 1-1.1: Manufacturer: FTDI
usb 1-1.1: SerialNumber: A9007TX5
usb 1-1.1: configuration #1 chosen from 1 choice
ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
usb 1-1.1: Detected FT232RL
usb 1-1.1: Number of endpoints 2
usb 1-1.1: Endpoint 1 MaxPacketSize 64
usb 1-1.1: Endpoint 2 MaxPacketSize 64
usb 1-1.1: Setting MaxPacketSize 64
usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
usb 2-1.2: new full speed USB device number 7 using ehci_hcd
usb 2-1.2: New USB device found, idVendor=0403, idProduct=6001
usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1.2: Product: FT232R USB UART
usb 2-1.2: Manufacturer: FTDI
usb 2-1.2: SerialNumber: A8008Izj
usb 2-1.2: configuration #1 chosen from 1 choice
ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
usb 2-1.2: Detected FT232RL
usb 2-1.2: Number of endpoints 2
usb 2-1.2: Endpoint 1 MaxPacketSize 64
usb 2-1.2: Endpoint 2 MaxPacketSize 64
usb 2-1.2: Setting MaxPacketSize 64
usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
lsusb reports both boards
Code:
bash-4.1$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 011: ID 0a5c:217f Broadcom Corp. Bluetooth Controller
Bus 001 Device 013: ID 04b3:310c IBM Corp. Wheel Mouse
Bus 001 Device 006: ID 17ef:480f Lenovo Integrated Webcam [R5U877]
Bus 001 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 002 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
bash-4.1$
only /dev/ttyUSB0 is visible in arduino
Code:
bash-4.1$ ls -l /dev/ttyU*
crw-rw-rw-. 1 root dialout 188, 0 Feb 27 16:17 /dev/ttyUSB0
crw-rw-rw-. 1 root dialout 188, 1 Feb 27 16:17 /dev/ttyUSB1
bash-4.1$
The only difference I see is the 0 and 1 before Feb for which I have no clue what it means. I found nothing in the man pages and when looking on google on what this value stands for.
executed as root I get he same result (except for the names having a black background)
Code:
[root@oc3604553758 jan]# ls -l /dev/ttyU*
As I belong to the dialout group this should be fine
Code:
bash-4.1$ groups
jan uucp dialout lock desktop_admin_r
bash-4.1$
Anyone has a clue what is wrong?
NewLinuxUser
Logged
Offline Offline
Newbie
View Profile
I tired with a 3th duemilenove board and 2 of them work and 1 doesn't.
It is kind of wierd because I can get the "bad board" to work in my xp VM.
Logged
Pages: [1]   Go Up
Print
Jump to:
