Loading...
Pages: [1]   Go Down
Author Topic: help reading diagram for button  (Read 164 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
hello,
i found this button in a drawer and it fits perfectly in the hole I want to install it in...I think I got it at RadioShack years ago. I googled it and all I found was this diagram:
http://www.sci.com.tw/PRODUCTS/AUTO%20ACCESSORIES/(R13)%20Car%20Switch/(A3)%20PUSH/R13-553.html
I can't really make sense of it. Right now I have pin 3 (LED pin) through a 1k resistor and in ground, pin 2 to the arduino and pin 1 in 12V. The arduino also shares the 12V ground.
The arduino isn't recognizing the button. i want the LED in the button to stay on all the time which it is now, but no pin reading. Any idea how I could rig this up to work with an arduino? i'm so bad at switches...
Thanks for any help!
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Do you own a multimeter? Try investigating it with that before you connect it to the Arduino.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
ah good idea hahaha. i'm so dumb. already fried a chip before using multimeter...but yeah it's working fine with multimeter.
so i think what the problem is, is that when the button is HIGH it's giving 12V to the arduino pin....how can i not do this?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Don't connect 12v to the button.
Logged
www.cmiyc.com - A guide to being an Enginerd
0
Offline Offline
Full Member
Yeah Arduino surely rocks !
View Profile
... when the button is HIGH it's giving 12V to the arduino pin....how can i not do this?
Maybe you are aware already but anyway: You will kill the digital pin or whole chip by feeding 12V to it's inputs.
It's hard to tell what you should do without knowing any details on how your stuff is wired. Did you have any schematics that show your actual button wiring? Are you doing anything different than http://arduino.cc/en/tutorial/button ?
Logged
Pages: [1]   Go Up
Print
Jump to:
