Loading...
Pages: [1]   Go Down
Author Topic: My Obstacle Avoiding Robot Code needs some Improvement!  (Read 205 times)
India
Offline Offline
Newbie
View Profile
WWW
Here is my code i tried on my obstacle avoiding robot. It's pretty basic. I used two 12V geared motors, HCSR04 as distance sensor, Micro 9G servo to rotate, UNO. I used 2 NPN transistors to isolate the motors from arduino so that i can power it using 9V battery. A HIGH signal to the base of transistor makes the motor ON. Given below is my code. Please provide your valuable suggestions.
Code:
#define trigPin 8
#define echoPin 12
#include <Servo.h>
 Servo myservo;
 void setup(){
  myservo.attach(9);
  pinMode(3,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
void servos()
    myservo.write(0);
if(ping()>40){
   digitalWrite(3,LOW);
   digitalWrite(6,LOW);
   digitalWrite(6,HIGH);
   delay(2000);
   digitalWrite(3,HIGH);
   delay(2000);
    myservo.write(90);
    delay(5000);
int ping(){
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  if (distance >= 200 || distance <= 0){
    Serial.println("Out of range");
  return(distance);
void loop(){
  Serial.print(ping());
    Serial.println("cm");
 if( ping()<40){
   digitalWrite(13,HIGH);
   servos();
 else{
   digitalWrite(13,LOW);
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Please post a schematic.
What kind of 9V battery?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Get rid of the delays. Look at the blink without delay example.
Mark
Logged
Pages: [1]   Go Up
Print
Jump to:
