Topic: Looking for a paid Programer to help with a project (Read 3191 times) previous topic - next topic
superedd
Hello, I am looking for someone to write for me a code for a project i am working on for the automotive industry.
It very basic, as i need to to have certain pulses in a different timing in a revolution of a four stroke engine.
Thanks
Superedd
CrossRoads
Variable timing, or static?
Reading them, or creating them?
superedd
Hi, Thanks for responding, The sensor will be placed to pick up teeth signal from cam shaft gear that will run between 500 to 2000 rpm
Will have to create signal pulses in specific position of the wheel, such signals will have to move few degrees to each side via a potentiometer (not based on speed)
Let me know if you have any additional questions
Thanks
Superedd
CrossRoads
So some kind of speed tracking kind of thing, like a strobe light that gets adjusted to make motion appear to freeze.
superedd
The pulses will via the Arduino pins will be connected through power circuits to activate valves, solenoids and other devices
