Topic: uploading code on arduino uno (Read 5351 times) previous topic - next topic
silverfin
I just started to get the error of
avrdude: stk500_getsync(): not in sync: resp=0x00
I'm not sure what that means or how i should proceed to fix it.
NewLinuxUser
Have you selected the correct board and serial port?
If this is not the problem: Please turn on verbose for upload and dump the content of the bottom part of the arduino IDE.
silverfin
Alright, i did that what should i be looking for, or not looking for?
silverfin
Nvm I found my problem it appears to be the usb port as it is a bit finicky with my mouse and it looks like the same for the arduino, switched ports and it works fine. I did not think it was the port at first as it never came up with the error of "wrong com" or anything like that.
thanks for your help though
nithan28
I have similar problem, i checked com port and board, every thing is proper.I even tried pressing reset before uploading nothing is working. I tried shift + upload and i got this:
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "D:\Softs\arduino-0023\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM18
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
Help me with this. Thanks a lot in advance.
cmiyc
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
nithan28
#6
Mar 03, 2013, 07:51 pm Last Edit: Mar 03, 2013, 07:54 pm by nithan28 Reason: 1
I used arduino 1.0.3 and not working for that also.
I tried shift + upload and it says:
avrdude: usbdev_open(): did not find any USB device "usb"
Thanks a lot  :)
cmiyc
What board do you have, where did you get it, and what board are you selecting in the IDE?
nithan28
I have Arduino UNO from Italy. I m selecting the same board in the IDE.
Thanks a lot for your reply.
cmiyc
The board can say anything.  I asked where (store/vendor) you bought it.
nithan28
I bought that from element14
It was working fine for a year but now i have this problem
Thanks a lot
cmiyc
nithan28
Sorry can you tell me how to get the loopback results?
Thanks a lot
cmiyc
Sticky link at the top of this forum.
nithan28
I m not getting the letters typed in the terminal. But i just see the Rx Led on when the key is pressed. So what should i do next?
Thanks a lot
