Author Topic: Changing Case of char Array  (Read 270 times)
Bald-Headed, Middle-Aged Nerd
I've read a lot about how some users "hate" the String Object and prefer to use char arrays when possible.  So I'm trying to become more proficient in using char arrays to store my strings.
Question:
What would the best way be to change the case of a string stored as a char array to Upper Case.
I see that there are already methods like strcmp and strcpy to perform other tasks on char arrays.
I can't seem to find something for changing case ( as exists for the String Object ).
Would appreciate any guidance on this.
Thank you.
Bob W
Dallas
Shannon Member
strupr
Pittsburgh, PA, USA
I only know some basic electricity....
For the ASCII alphas, bit 5 is the difference in case.
1 loop the length of the buffer with break on NULL, if the ASCII is not alpha-only then with a range check ( data & 0xDF >= 'A' ) && ( data & 0xDF <= 'Z' ) and either set or clear bit 5.... make the state an arg and 1 function could do both change to upper or lower case.
And you don't need string.h to do that.
Examples can be found at Learning in the Main Site and at the Playground
That worked *good*  !
I like it.
Thanks for helping me !
Bob
This is certainly easier.
I don't know why I couldn't find it myself.
Thanks you !
Bob
strupr
Pittsburgh, PA, USA
char array strings are so simple and easy to get at I have to wonder at the use of String objects that 'protect' the data from the programmer. What kind of programmers does data need protection from? Can't be -good- ones!
Mr. "Smoke":
Below is how I tested your suggestion to UpCase a string.
Works good.
Doesn't look very good.
Can you suggest how I can get rid of the for loop and replace it with a while (myString != NULL) ?
I don't see how to step through the buffer without an index like "i".
Thanks.
Bob W.
char myString[] = "Hello";
  for (int i = 0; i < 100; i++ )  // 100 set arbitrarily and excessively large
    if ( myString[i] == NULL ) break;
    myString[i] = myString[i] & 0b11011111;
  Serial.print( &myString[0] );
Seattle, WA USA
Seattle, WA USA
Replace the 100 with strlen(myString) and delete the comment.
And you can remove the if test.
Pittsburgh, PA, USA
As long as I'm gonna do it, I'll use a pointer and stick with hex.
char myString[] = "Hello Again";
char *ch;
  ch = myString;
  while (*ch) // exits on terminating NULL
    if (( *ch &0xDF >= 'A' ) && ( *ch & 0xDF <= 'Z' ))  *ch &= 0xDF; // so that bit 5 only gets cleared for alphas
  Serial.println( myString );
Rome, Italy
    if (( *ch & 0xDF >= 'A' ) && ( *ch & 0xDF <= 'Z' ))  *ch &= 0xDF; // so that bit 5 only gets cleared for alphas
// this was left as an exercise for the student
    ch++;
Pittsburgh, PA, USA
Whups! Where's my old dunce cap?
UK
Online Online
for (int i = 0; myString [i]; i++ )
    myString[i] &= 0b11011111;
