Topic: TFT library alters values in a struct (Read 693 times) previous topic - next topic
bobo01
Feb 28, 2013, 07:30 pm Last Edit: Feb 28, 2013, 07:41 pm by bobo01 Reason: 1
Hello,
I have the following code.
Code: [Select]
Serial.println("sensorUIInfo->airTemp MAIN C");
getAirTemp();  //Air Temp = 23
 //Draw pH value
 myGLCD.printNumF(sensorUIInfo->phLevel, 1, 20, 120);
 Serial.println("sensorUIInfo->airTemp MAIN D");
getAirTemp();  //Air Temp = 32
The reason is that printNumF, if I do printNumI or nothing it's OK.  Somehow that printF alters the value.
The struct is like this:
Code: [Select]
//All the data from the HW sensors.
   struct SENSOR{
   float phLevel;
   float eCLevel;
   int airTemp;
   int waterTemp;
SENSOR* sensorUIInfo;
And I update from the engine to the UI like this:
Code: [Select]
void HydroponicsUI::updateInfoFromSensors( SENSOR* sensorInformation )
Serial.println("sensorInformation->airTemp");
Serial.println(sensorInformation->airTemp);
sensorUIInfo->phLevel = sensorInformation->phLevel;
sensorUIInfo->eCLevel = sensorInformation->eCLevel;
sensorUIInfo->airTemp = sensorInformation->airTemp;
sensorUIInfo->waterTemp =  sensorInformation->waterTemp;
The controller does the update like this:
Code: [Select]
//Update the UI of the latest Sensor Info
  Hydro_UI.updateInfoFromSensors( Hydro_Eng.getSensorInformation() );
Is this an error in my code?
Thanks.
bobo01
Also:
If I pass by reference it is working OK.  Any ideas what mistake I made when using those pointers?  Are pointers the correct way to do it here?
