Topic: error compile my code (Read 2932 times) previous topic - next topic
smallpoul
Here the code:
// Demo using DHCP and DNS to perform a web client request.
// 2011-06-08 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
#define garderobe "82"
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
char website[] PROGMEM = "192.168.2.19";
static byte hisip[] = {192,168,2,19};
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
  Serial.println(">>>");
  Ethernet::buffer[off+300] = 0;
  Serial.print((const char*) Ethernet::buffer + off);
  Serial.println("...");
void setup () {
  Serial.begin(57600);
  Serial.println("\n[webClient]");
  mySwitch.enableReceive(1);
  if (ether.begin(sizeof Ethernet::buffer, mymac, 10) == 0)
    Serial.println( "Failed to access Ethernet controller");
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
  ether.copyIp(ether.hisip, hisip);
  ether.hisport = 3480;
  ether.printIp("SRV: ", ether.hisip);
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
void loop () {
  ether.packetLoop(ether.packetReceive());
   if (mySwitch.available()) {
    unsigned long code = mySwitch.getReceivedValue();
    Serial.print("Received :");
    Serial.println( code );
    if (code == 5586965)
    mySwitch.resetAvailable();
    sendtovera(garderobe);
void sendtovera(String devid){
ether.browseUrl(PSTR("/data_request?id=action&DeviceNum=52&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue="), devid, website, my_callback);
error:
nc28j60.cpp: In function 'void sendtovera(String)':
enc28j60:63: error: no matching function for call to 'EtherCard::browseUrl(char*, String&, char [13], void (&)(byte, word, word))'
/Users/Michael/Documents/Arduino/libraries/ethercardmaster/EtherCard.h:164: note: candidates are: static void EtherCard::browseUrl(prog_char*, const char*, prog_char*, void (*)(uint8_t, uint16_t, uint16_t))
I'm loss, i thing that ether card do not like string but not sure
thanks
Arrch
thanks
Actually, it loves strings. Strings, on the hand, it's not too fond of.
smallpoul
maybe it late here but i don't understand what you means?
Sorry
MaJiG
The C compiler is case-sensitive.
smallpoul
Normally to call it i use String not string, if i put string, it say that i have not  declare it.
smallpoul
Ok other method, let say i want to insert value in the url:
ether.browseUrl(PSTR("/data_request?id=action&DeviceNum=(((HERE))&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue="), "1", website, my_callback);
In python i use the s% function like this:
"/data_request?id=action&DeviceNum=%s&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=" $ devid
but is there a way in arduino code
thanks
spatula
No, forget the other method whatever it was intended to mean. Look at your error message:
See how the compiler suggests something that could work:
... note: candidates are: static void EtherCard::browseUrl(prog_char*, const char*, prog_char*, void (*)(uint8_t, uint16_t, uint16_t))
The main difference between the parameters you are passing and the parameters that the compiler expects is... the String& parameter. Now if you look at your code around line 63 (as the compiler tells you) you see that devid is declared as a String. Can you change it into a (const) char*? The funny thing is that garderobe is actually a char*, but you (implicitly) convert it into a String when you call sendtovera(). Just redefine sendtovera() to accept a char* and it should fix the error.
Btw, the C equivalent of s% in python is sprintf().
