Topic: TCP Software for Windows (solved) :) (Read 817 times) previous topic - next topic
Malibux
Apr 05, 2013, 08:43 pm Last Edit: Apr 06, 2013, 10:54 am by Malibux Reason: 1
Im not sure im posting this in the right place but I hope you can help me anyway. :)
I have thanks to some helpful people from this forum created a TCP script for my arduino. The code is below:
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address, IP address and Portnumber for your Server below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress serverIP(192,168,1,45);
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(5190); //server port
// Initialize the Ethernet server library
// with the IP address and port you want to use
int led = 8;
 pinMode(led, OUTPUT);
 // start the serial for debugging
 // start the Ethernet connection and the server:
 Ethernet.begin(mac, serverIP, gateway, subnet);
 server.begin();
 Serial.println("Server started");//log
 if (client) {
   while (client.connected()) {
     if (client.available()) {
       char ch = client.read();
// examine ch
       switch(ch)
       case 'on':  // for example
   digitalWrite(led, HIGH);
   client.println("The power is ON");
   delay(10);
       case 'of':  // for example
    digitalWrite(led, LOW);
    client.println("The power is OFF");
    delay(10);
But now I need a free software for my computer(windows 7) which can connect to the Arduino and i can type in and send the commands to the arduino.
Can anyone help me?
Thanks in advance
SurferTim
That part is not a problem. Internet Explorer, Chrome, Safari, Firefox. Any web browser. Is that what you meant? In the address bar:
http://192.168.1.45:5190
Kai_Heinz
I guess you want to establish the TCP connection from your PC? That is super easy: just use the browser! Try this line: "192.168.1.1:5190", the first part is the IP-Address of your arduino, the part after the colon is the port you are sending on.
PeterH
#3
Apr 05, 2013, 10:09 pm Last Edit: Apr 05, 2013, 10:12 pm by PeterH Reason: 1
Code: [Select]
That isn't going to do what you expect. What you're doing there is reading one byte, and then comparing it to a multibyte character - which it won't match.
What you're trying to do needs you to read a string from the TCP stream, and then compare the string against your expected values. This is very similar to the technique used to receive commands over the serial port and you will find lots of examples of that.
For an easy life, use a web server instead of reading and processing the TCP input directly.
If you decide to stick to raw TCP, you can use something like telnet or PuTTY to connect and send arbitrary bytes over a TCP socket. If you use a browser as suggest, you'll be sending an HTTP request and you would then be back to needing a web server to parse that request - whether a standard one, or one you hack together for yourself.
Malibux
#4
Apr 06, 2013, 10:12 am Last Edit: Apr 06, 2013, 10:53 am by Malibux Reason: 1
Code: [Select]
I would like to stick with the TCP raw because i already found an app for my mobile phone(TCP Client) which can work with this code.. and now i found a program which can do it.. thanks you all for the help
