Topic: how to interface IR distance sensor with flame sensor (Read 2258 times) previous topic - next topic
chokey
Is there anyone in this room that can show me some example on how to interface IR distance sensor with flame sensor. I'm a newbie. tq
zoomkat
What is the expected result of this combination? Do you have links to the IR distance sensor and flame sensor?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
chokey
Forgot to mention, I want to build a robot that can extinguish from a certain distance. I have done interface the middle range IR sensor with motor. The problem is how to interface the flame sensor with middle range IR sensor so that the robot will stop when detecting a flame from a certain distance.
PeterH
IR distance sensors usually work by reflection. I think you will have a hard time getting an IR signal to reflect off a flame, and an even harder time telling the difference between the reflected signal and the heat of the flame. In other words, it seems to me that the approach you're taking is a complete non-starter.
zoomkat
You might use an ultrasonic range finder like below to determine the distance to something burning (assuming it has some detectable size). Just depends on what type environment the bot has to operate.
http://www.maxbotix.com/Ultrasonic_Sensors.htm#LV-EZ
