Topic: Problem about UDP send with ethercard ENC28J60(Solve Now) (Read 10502 times) previous topic - next topic
superid888
Feb 28, 2013, 04:33 pm Last Edit: Mar 02, 2013, 09:46 am by superid888 Reason: 1
Hi
I'am from China ?I'am sorry for my poor english.
I have a problem about UDP send with ethercard.
My problem is about:
I use Arduino uno3+ ENC28J60 + DHT11 + two 7segment  LED to  display temperature and humidity and send data to host PC by UDP , all the hardware and sub-module test normal, the ENC28J60 CS connect to D10, the measured power supply voltage for ENC28J60 is 3.3V, The IDE with the 1.03 version, EtherCard withis the latest version. all functions in normal when I running wireshake to capture data on host PC,I got correctly display of temperature and humidity and the received UDP data is OK, but when I stop capture data with wireshake,the host computer can not receive UDP data, what possible with the problem?
Thanks!
the code as below?
Code: [Select]
//CS?D10?SI?D11?SO?D12?SCK?D13
#include <EtherCard.h>
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myip[] = {192,168,2,23};
static byte gwip[] = {192,168,23,254};
byte Ethernet::buffer[100];
static byte destip[]= {192,168,2,10};
static int myport=1002,destport=1001;
// bits representing segments A through G (and decimal point) for numerals 0-9
const int numeral[10] = {
//ABCDEFG /dp
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B10111110, // 6
B11100000, // 7
B11111110, // 8
B11110110, // 9
// pins for decimal point and each segment
// dp,G,F,E,D,C,B,A
const int segmentPins[] = { 9,8,7,6,5,4,3,2};
const int nbrDigits= 2; // the number of digits in the LED display
//dig 1 2
const int digitPins[nbrDigits] = { A4,A5};
int dppin=A3; //set the decimal point link to PIN A3
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN A0 //DHT11 PIN 3 ?UNO A0
char string1[2];//humidity
char string2[2];//temperature
 Serial.begin(19200);
 if (ether.begin(sizeof Ethernet::buffer, mymac, 10) == 0)
   Serial.println( "Failed to access Ethernet controller");
 if (!ether.staticSetup(myip))
   Serial.println("Failed to set IP address");
//    ether.setGwIp(gwip);
for(int i=0; i < 8; i++)
pinMode(segmentPins[i], OUTPUT); // set segment and DP pins to output
for(int i=0; i < nbrDigits; i++)
pinMode(digitPins[i], OUTPUT);
 int chk = DHT11.read(DHT11PIN);
 Serial.print("Read sensor: ");
 switch (chk)
  case DHTLIB_OK:
               Serial.println("OK");
   case DHTLIB_ERROR_CHECKSUM:
               Serial.println("Checksum error");
   case DHTLIB_ERROR_TIMEOUT:
               Serial.println("Time out error");
   default:
               Serial.println("Unknown error");
int humd=int(DHT11.humidity);
int temp=int(DHT11.temperature-2);
itoa(humd,string1,10);
itoa(temp,string2,10);
//ether.udpPrepare(myport,destip,destport);
//ether.udpTransmit(4);
ether.sendUdp ((char*) string1, 64, myport, destip, destport);
Serial.println("DATA send by UDP!");
Serial.println(humd);
Serial.println(temp);
//  delay(2000);
//Display on 7segment
 int counter1=200;
while(counter1)
   counter1--;
//    showNumber(DHT11.humidity);
showNumber(humd);
   counter1=200;
while(counter1)
   counter1--;
   analogWrite(dppin,0);
//    showNumber(DHT11.temperature-2);
showNumber(temp);
   analogWrite(dppin,200);
void showNumber( int number)
if(number == 0)
showDigit( 0, nbrDigits-1) ; // display 0 in the rightmost digit
// display the value corresponding to each digit
// leftmost digit is 0, rightmost is one less than the number of places
for( int digit = nbrDigits-1; digit >= 0; digit--)
if(number > 0)
showDigit( number % 10, digit) ;
number = number / 10;
// Displays given number on a 7-segment display at the given digit position
void showDigit( int segnumber, int digit)
digitalWrite( digitPins[digit], HIGH );
for(int segment = 1; segment <8; segment++)
boolean isBitSet = bitRead(numeral[segnumber], segment);
// isBitSet will be true if given bit is 1
//isBitSet = ! isBitSet; // remove this line if common cathode display
digitalWrite( segmentPins[segment], isBitSet);
delay(5);
digitalWrite( digitPins[digit], LOW );
pylon
WinShake doesn't capture network data. Did you mean WireShark?
If you can capture the data sent by the Arduino on your PC, the Arduino side is doing fine. I don't know what you mean by "host computer can not receive UDP data". What program do you use to receive the data?
superid888
Sorry, the program I used to capture network data is WinShake. I've try several different program on host PC and got the same result.
"host computer can not receive UDP data" mean when I do the capturing with winshake, the program I use to receive UDP data can got correct result, when I stop capturing with winshake, the program I use to receive UDP data can't received any data.
superid888
#3
Mar 01, 2013, 12:22 am Last Edit: Mar 01, 2013, 11:12 am by superid888 Reason: 1
I do a test by replace ENC28J60 with W5100 ,I got a correct correct result without runing winshask.
The code as below?
Code: [Select]
This sketch receives humidity and temperature from sensor DHT11,
display on two digits seven-segment LED and send UDP message to remote server, prints them to the serial port.
Created 10 Feb 2013, by Chen JW, superid888@gmail.com
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>       // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 2, 23);
static byte ServerIp[] = {192,168,2,10};
unsigned int localPort = 1000,ServerPort=1001;      // set local port and server port
// buffers for receiving and sending data
char packetBuffer[100]; //buffer to hold incoming packet,
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
//ABCDEFG /dp
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B10111110, // 6
B11100000, // 7
B11111110, // 8
B11110110, // 9
// dp,G,F,E,D,C,B,A
//dig 1 2
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN A0 //DHT11 PIN 3 ??UNO A0
char string1[2];//set char to humidity
char string2[2];//set char to temperature
 // start the Ethernet and UDP:
 Ethernet.begin(mac,ip);
 Udp.begin(localPort);
pinMode(segmentPins[i], OUTPUT); // set segment pins to output
 switch (chk)
  case DHTLIB_OK:
   default:
   // send UDP packet
   Udp.beginPacket(ServerIp, ServerPort);
   Udp.write((char*) string1);
   Udp.endPacket();
Serial.println("UDP DATA send !");
 int counter1=200;
while(counter1)
   counter1--;
showNumber(humd);
   counter1=200;
while(counter1)
   counter1--;
showNumber(temp);
if(number == 0)
if(number > 0)
delay(5);
SurferTim
Did you notice the w5100 code starts UDP listening on a port. I did not see that in the ENC28J60 code. There must be a similar function.
Code: [Select]
superid888
Yes,I think the code for UDP in ethercard maybe short of  something for bind sorport to  disport,but I don't know how to modify the library.
superid888
I don't know how to use ether.udpTransmit() for Transmit udp data,can someone give me a example?
Thanks!
superid888
I try another Library for ENC28J60 today?everything is OK and the .HEX file is smaller.
The code can only compily by IDE 002X
Created 10 Feb 2013, by Chen JW. superid888@gmail.com
#include "EtherShield.h"
static uint8_t mymac[6] = { 0x54,0x55,0x58,0x10,0x00,0x25};
static uint8_t myip[4] = { 192,168,2,23};
static uint8_t broadcastip[4] = { 192,168,2,255};
// DestPort 1001, SrcPort 1000
#define DEST_PORT_L  0xE9
#define DEST_PORT_H  0x03
#define SRC_PORT_L  0xE8
#define SRC_PORT_H  0x03
const char iphdr[] PROGMEM ={ 0x45,0,0,0x82,0,0,0x40,0,0x20}; // 0x82 is the total
struct UDPPayload {
uint8_t data[2];
UDPPayload udpPayload;
// Packet buffer, must be big enough to packet and payload
#define BUFFER_SIZE 150
static uint8_t buf[BUFFER_SIZE+1];
EtherShield es=EtherShield();
//ABCDEFG /dp
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B10111110, // 6
B11100000, // 7
B11111110, // 8
B11110110, // 9
// dp,G,F,E,D,C,B,A
//dig 1 2
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN A0 //DHT11 PIN 3 == UNO A0
char string1[2];//Humd
char string2[2];//Temp
void setup(){
  es.ES_enc28j60Init(mymac);
  //init the ethernet/ip layer:
  es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
pinMode(segmentPins, OUTPUT); // set segment and DP pins to output
pinMode(digitPins, OUTPUT);
//  delay(1000);
void loop(){
  switch (chk)
   case DHTLIB_OK:
    default:
//itoa(humd,string1,10);
//itoa(temp,string2,10);
//byte babb = 0x45;
//string ass = ((char)babb).ToString();
udpPayload.data[0] =humd;
udpPayload.data[1] =temp;
//udpPayload.data[0] =string1;
//udpPayload.data[1] =string2;
broadcastData() ;
  int counter1=200;
while(counter1)
    counter1--;
showNumber(humd);
    counter1=200;
while(counter1)
    counter1--;
showNumber(temp);
// Broadcast the data in the udpPayload structure
void broadcastData( void ) {
  uint8_t i=0;
  uint16_t ck;
  // Setup the MAC addresses for ethernet header
  while(i<6){
    buf[ETH_DST_MAC +i]= 0xff; // Broadcsat address
    buf[ETH_SRC_MAC +i]=mymac;
    i++;
  buf[ETH_TYPE_H_P] = ETHTYPE_IP_H_V;
  buf[ETH_TYPE_L_P] = ETHTYPE_IP_L_V;
  es.ES_fill_buf_p(&buf[IP_P],9,iphdr);
  // IP Header
  buf[IP_TOTLEN_L_P]=28+sizeof(UDPPayload);
  buf[IP_PROTO_P]=IP_PROTO_UDP_V;
  i=0;
  while(i<4){
    buf[IP_DST_P+i]=broadcastip;
    buf[IP_SRC_P+i]=myip;
    i++;
  es.ES_fill_ip_hdr_checksum(buf);
  buf[UDP_DST_PORT_H_P]=DEST_PORT_H;
  buf[UDP_DST_PORT_L_P]=DEST_PORT_L;
  buf[UDP_SRC_PORT_H_P]=SRC_PORT_H;
  buf[UDP_SRC_PORT_L_P]=SRC_PORT_L; // lower 8 bit of src port
  buf[UDP_LEN_H_P]=0;
  buf[UDP_LEN_L_P]=8+sizeof(UDPPayload); // fixed len
  // zero the checksum
  buf[UDP_CHECKSUM_H_P]=0;
  buf[UDP_CHECKSUM_L_P]=0;
  // copy the data:
  i=0;
  // most fields are zero, here we zero everything and fill later
  uint8_t* b = (uint8_t*)&udpPayload;
  while(i< sizeof( UDPPayload ) ){
    buf[UDP_DATA_P+i]=*b++;
    i++;
  // Create correct checksum
  ck=es.ES_checksum(&buf[IP_SRC_P], 16 + sizeof( UDPPayload ),1);
  buf[UDP_CHECKSUM_H_P]=ck>>8;
  buf[UDP_CHECKSUM_L_P]=ck& 0xff;
  es.ES_enc28j60PacketSend(42 + sizeof( UDPPayload ), buf);
if(number == 0)
if(number > 0)
delay(5);
// End
melvinlo
hi,
the below function works fine , i am using UDP client in java to test all send and receive works fine,
check your ports may be you are making a mistake there.
ether.sendUdp(msg, sizeof msg, 1337, ipDestination, 1111);
melvinlo
   If the Gateway IP is wrong only receive works , and send dose not, check the gateway IP and enter the correct Gateway IP the Code will work properly after that.
LuBoss
I have good setup gateway and UDP receive is ok, but send not work.
If I use web client, not to be setup MASK! With correct mask web client not working.
My LAN is 172.16.0.0 and MASK 255.255.0.0
