Hi. I'm following this tutorial: RFID 13.56 MHz / NFC Module for Arduino
http://www.cooking-hacks.com/index.php/blog/tutorial-rfid-13-56-mhz-nfc-module-for-arduino
using this code:
uint8_t dataRX[35];//Receive buffer.
uint8_t dataTX[35];//Transmit buffer.
uint8_t _UID[4];// stores the UID (unique identifier) of a card.
uint8_t keyAccess[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF } ;// stores the key or password.
uint8_t address = 0x04;//Address to read.
uint8_t ATQ[2];//Answer to request
uint8_t state;//state of the process
uint8_t aux[16];//Auxiliar buffer.
//Start serial port 115200 bps:
delay(100);
Serial.print("RFID/NFC @ 13.56 MHz module started");
//!It is needed to launch a simple command to sycnchronize
getFirmware();
configureSAM();
Serial.print("\n");
Serial.println("Ready to read...");
//Get the UID Identifier
init(_UID, ATQ);
Serial.print("\n");
Serial.print( "The UID : ");
print(_UID , 4);
//Auntenticate a block with his keyAccess
state = authenticate(_UID, address, keyAccess);
Serial.print("\n");
if ( state == 0) {
Serial.println("Authentication block OK");
Serial.println("Authentication failed");
//Read from address after authentication
state = readData(address, aux);
Serial.print("\n");
if (state == 0) {
Serial.println("Read block OK");
Serial.println("Read failed");
Serial.print("\n");
Serial.print("Data read : ");
print(aux , 16);
Serial.print("\n");
delay(2000);
//!The goal of this command is to detect as many targets (maximum MaxTg)
// as possible in passive mode.
uint8_t init(uint8_t *UID , uint8_t *ATQ) //! Request InListPassive
Serial.flush();
dataTX[0] = 0x04; // Length
lengthCheckSum(dataTX); // Length Checksum
dataTX[2] = 0xD4;
dataTX[3] = 0x4A; // Code
dataTX[4] = 0x01; //MaxTarget
dataTX[5] = 0x00; //BaudRate = 106Kbps
dataTX[6] = 0x00; // Clear checkSum position
checkSum(dataTX);
sendTX(dataTX , 7 ,23);
for (int i = 17; i < (21) ; i++){
_UID[i-17] = dataRX[i];
UID[i-17] = _UID[i-17];
ATQ[0] = dataRX[13];
ATQ[1] = dataRX[14];
if ((dataRX[9]== 0xD5) & (dataRX[10] == 0x4B) & (dataRX[11] == 0x01)) {
return 0;
return 1;
//!A block must be authenticated before read and write operations
uint8_t authenticate(uint8_t *UID, uint8_t blockAddress, uint8_t *keyAccess)
dataTX[0] = 0x0F;
dataTX[2] = 0xD4;
dataTX[3] = 0x40; // inDataEchange
dataTX[4] = 0x01; //Number of targets
dataTX[5] = 0x60; // Authentication code
dataTX[6] = blockAddress;
for (int i = 0; i < 6 ; i++) {
dataTX[i + 7] = keyAccess[i];
dataTX[13] = UID[0]; dataTX[14] = UID[1];
dataTX[15] = UID[2]; dataTX[16] = UID[3];
dataTX[17] = 0x00;
checkSum(dataTX);
sendTX(dataTX , 18 ,14);
if ((dataRX[9]== 0xD5) & (dataRX[10] == 0x41) & (dataRX[11] == 0x00)) {
return 0;
return 1;
//!Write 16 bytes in address .
uint8_t writeData(uint8_t address, uint8_t *blockData) //!Writing
Serial.print(" ");
dataTX[0] = 0x15;
dataTX[2] = 0xD4;
dataTX[3] = 0x40;//inDataEchange CODE
dataTX[4] = 0x01;//Number of targets
dataTX[5] = 0xA0;//Write Command
dataTX[6] = address; //Address
for (int i = 0; i < 16; i++) {
dataTX[i+7] = blockData[i];
dataTX[23] = 0x00;
checkSum(dataTX);
sendTX(dataTX , 24 ,14);
return 0;
return 1;
//!Read 16 bytes from address .
uint8_t readData(uint8_t address, uint8_t *readData) //!Reading
Serial.print(" ");
dataTX[0] = 0x05;
dataTX[2] = 0xD4; // Code
dataTX[3] = 0x40; // Code
dataTX[4] = 0x01; // Number of targets
dataTX[5] = 0x30; //ReadCode
dataTX[6] = address; //Read address
dataTX[7] = 0x00;
checkSum(dataTX);
sendTX(dataTX , 8, 30);
memset(readData, 0x00, 16);
for (int i = 12; i < 28; i++) {
readData[i-12] = dataRX[i];
return 0;
return 1;
//!The PN532 sends back the version of the embedded firmware.
bool getFirmware(void) //! It is needed to launch a simple command to sycnchronize
Serial.print(" ");
memset(dataTX, 0x00, 35);
dataTX[0] = 0x02; // Length
dataTX[2] = 0xD4; // CODE
dataTX[3] = 0x02; //TFI
checkSum(dataTX); //0x2A; //Checksum
sendTX(dataTX , 5 , 17);
Serial.print("\n");
Serial.print("Your Firmware version is : ");
for (int i = 11; i < (15) ; i++){
Serial.print(dataRX[i], HEX);
Serial.print(" ");
Serial.print("\n");
//!Print data stored in vectors .
void print(uint8_t * _data, uint8_t length)
for (int i = 0; i < length ; i++){
Serial.print(_data[i], HEX);
Serial.print(" ");
Serial.print("\n");
//!This command is used to set internal parameters of the PN532,
bool configureSAM(void)//! Configure the SAM
Serial.print(" ");
dataTX[0] = 0x05; //Length
dataTX[2] = 0xD4;
dataTX[3] = 0x14;
dataTX[4] = 0x01; // Normal mode
dataTX[5] = 0x14; // TimeOUT
dataTX[6] = 0x00; // IRQ
dataTX[7] = 0x00; // Clean checkSum position
checkSum(dataTX);
sendTX(dataTX , 8, 13);
//!Send data stored in dataTX
void sendTX(uint8_t *dataTX, uint8_t length, uint8_t outLength)
Serial.write(byte(0x00));
Serial.write(byte(0xFF));
for (int i = 0; i < length; i++) {
Serial.write(byte(dataTX[i]));
getACK();
waitResponse();// Receive response
getData(outLength);
//!Wait for ACK response and stores it in the dataRX buffer
void getACK(void)
delay(5);
waitResponse();
for (int i = 0; i < 5 ; i++) {
dataRX[i] = Serial.read();
//!Wait the response of the module
void waitResponse(void)
int val = 0xFF;
int cont = 0x00;
while(val != 0x00) { //Wait for 0x00 response
val = Serial.read();
delay(5);
cont ++;
//!Get data from the module
void getData(uint8_t outLength)
for (int i=5; i < outLength; i++) {
dataRX[i] = Serial.read();//read data from the module.
//!Calculates the checksum and stores it in dataTX buffer
void checkSum(uint8_t *dataTX)
for (int i = 0; i < dataTX[0] ; i++) {
dataTX[dataTX[0] + 2] += dataTX[i + 2];
byte(dataTX[dataTX[0] + 2]= - dataTX[dataTX[0] + 2]);
//!Calculates the length checksum and sotres it in the buffer.
uint8_t lengthCheckSum(uint8_t *dataTX)
dataTX[1] = byte(0x100 - dataTX[0]);
The only I get on the Monitor Serial is:
What could I do?
Thanks
