Topic: Can't get this switch / case sketch to work. Any ideas? (Read 3496 times) previous topic - next topic
PlasticOne
The program was suppose to run an RGB led with a lot of different functions off of one button but it was to many to cycle throw so i thought i could add a second button to brake down the functions making it easier to use so one button cycle the colours whilst the other dealt with the colours functions but iv made a but of a mess any help would be greatly appreciated. A small sample of the code
Code: [Select]
const int redledPin = 2;
const int greenledPin = 1;
const int blueledPin = 0;
const int buttonPin = 3;
const int buttonPin2 = 4;
int RGB=1;
int B2=2;
int prevUp = HIGH;
int prevDn = HIGH;
void setup ()
  pinMode (redledPin, OUTPUT);
  pinMode (greenledPin, OUTPUT);
  pinMode (blueledPin, OUTPUT);
  pinMode (buttonPin, INPUT);
void loop ()
int currUp = digitalRead(buttonPin2);
   if(currUp != prevUp)
      delay(5);
         if(currUp == LOW)
            B2++;
   switch (B2)
     case 1:{
int currUp = digitalRead(buttonPin);
      delay(5);
         if(currUp == LOW)
            RGB++;
   switch (RGB){
    case 1:
    analogWrite(redledPin, 0);
    analogWrite(blueledPin, 250);
    analogWrite(greenledPin, 0);
    delay(200);
    delay(100);
    case 2:
    prevUp = currUp;
  case 2:{
      delay(5);
         if(currUp == LOW)
            RGB++;
   switch (RGB){
    case 1:
    analogWrite(blueledPin, 0);
    analogWrite(greenledPin, 250);
    delay(200);
    delay(100);
    case 2:
    prevUp = currUp;
  }break;
Arrch
Start by putting any curly brace on its own line and using the auto format tool (In the Arduino IDE, under Tools) to make the code more readable. The seemingly random indentation is distracting.
MaJiG
You have a curly brace out of place, methinks
Code: [Select]
   switch (B2)
     case 1:{
should be
Code: [Select]
   switch (B2)
     case 1:
you may need to match closing brackets.
The curly brackets after the "case 1:" isn't necessary, btw.
UKHeliBob
Code: [Select]
  switch (B2)
  case 1:
should be
Code: [Select]
  switch (B2)
  case 1:
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Grumpy_Mike
You can't define a variable inside a switch statement. Define that int outside first and then assign it a value inside the switch.
PaulS
Quote
Actually, you can, if the variable is defined in a block. That is why each case starts and ends with { and },
PlasticOne
Still no joy : / thanks for the help anyway guys : ) is there an easier way to achieve a switch case within a switch case only using two inputs?
PeterH
There's nothing difficult about using one switch statement inside another. I have no idea whether it's a sensible solution for whatever your problem is, but it's straight forward to code. However, you do need to get the syntax right and put your curly brackets in the right place and so on - just as with any other code.
nickgammon
Show your amended code, thanks.
You might want to put stuff into functions, I can't make out what you are trying to do.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
int B2=2;
      if(currUp == LOW)
        B2++;
  switch (B2)
B2 is going to keep going up and up, right?
PlasticOne
Ok so i scraped the first code redid a lot of it and came up with this layout still not working but i think its in beter shape than the first
Code: [Select]
int RGB=1;
int RGB2=2;
int prevUp = HIGH;
int prevDn = HIGH;
void setup ()
  pinMode (buttonPin2, INPUT);
void loop ()
int currUp = digitalRead(buttonPin && buttonPin2);
      delay(25);
         if(currUp == LOW)
            RGB++ && RGB2;
  switch (RGB){
    case 1:
   switch (RGB2){
    case 1:
    case 2:
    case 3:
    analogWrite(redledPin, 250);
    case 4:
    case 5:
    prevUp = currUp;
    case 2:
    switch (RGB2){
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
    prevUp = currUp;
PaulS
Code: [Select]
In English, what is this supposed to be doing? It isn't, but I haven't any idea how to change it, because I have no idea what you think it does.
Code: [Select]
            RGB++ && RGB2;
And this?
