Loading...
Pages: [1] 2   Go Down
Author Topic: Sharing compiled code?  (Read 537 times)
Offline Offline
Newbie
View Profile
I did search but wasn't able to find anything. Mostly because I'm probably not searching with the correct terminology..
What I'd like to do is compile code for my Uno to share with the UI developer that has no need to compile or see the source code.
Seems like a pretty basic requirement but I'm fairly new to embedded code on the Arduino so I'm not sure how to approach this.
Thanks,
Joshua
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
AFAIK that's not practical (or even possible) with small embedded systems.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Newbie
View Profile
Really? So you have to compile and download in one shot? I can't imagine why that would be the case. But as I said I'm knew to 'duino...
Logged
Quebec, Canada
Offline Offline
Newbie
View Profile
You should probably do that with the .hex (it's the hex code of the microcontroller) But not sure how can you upload the code with the Arduino IDE once  other people got the .hex file..
Logged
Offline Offline
Newbie
View Profile
Yes! But if you compile the source code where is it compiled to?
I think AVRDude is the way to upload files to 'duino...
THanks!
Logged
Offline Offline
Tesla Member
View Profile
WWW
Actually I'm pretty rusty on this end of things these days and I also thought you meant at run time. You can probably compile your code to an object file then have people include that in their project at the link stage. But I don't think you could do that under the Arduino IDE, you'd have to get down and dirty with make files.
I'm prepared to be corrected though.
_____
Rob
« Last Edit: March 01, 2013, 02:21:50 am by Graynomad » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
%TEMP%
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Correct.  Turn on verbose output to see the exact command line.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
There's also ways to upload .hex files in a standalone method
http://www.gammon.com.au/forum/?id=11638
or commercially with
http://www.kanda.com/products/Kanda/HH0110.html
will do the fuses & load program.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
You could let the UI developer work with paper and pencil and after his storyboards/sketches are agreed upon you could implement them .
Is that an option?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Tesla Member
View Profile
WWW
As I understand it the OP wants to provide a "module" for developers to include with their program. In other words a library but without the source code.
Is that the case? If so it can't be done at the HEX file level surely.
_____
Rob
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
Is that the case?
Can't tell for certain.  The requirements are ambiguous.
Quote
Probably not.
We'll have to wait for clarity from @joshuaj.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
alternative is to make fake code with the same interface for the UI.  No need to share the secret parts...
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Tough crowd!  ]smiley
I need to provide updates for the micro to the UI developer in a remote location. He's not an embedded developer and has no need to see the source code. He just needs update to functionality as they become available.
Logged
Offline Offline
Newbie
View Profile
Thanks!
Logged
Pages: [1] 2   Go Up
Print
Jump to:
