Author Topic: Need help!!  (Read 128 times)
LED program not working need help dont know why
Below is code
void setup (){
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
void loop(){
  int Portresult;
  int val;
  int bitval;
  int counter = 0;
   for ( counter=0; counter = 5; counter++){
     bitRead(Portresult,counter);
      val=bit(counter);
      counter = counter + 2;
      if(val=='1') { digitalWrite(counter,HIGH) ; }
      else if (val=='0') {digitalWrite(counter,LOW);
Below is code
Well, I have no idea what the code is supposed to do.  You should probably tell what you want it to do.  I don't have a crystal ball and I can't read minds.
I have no idea what actually happens.  You should probably tell that too.  I mean if you really want help.
But I do know that this for loop will never execute.  On the very first iteration counter is 0 and the condition to run the loop says it has to equal 5.  0 != 5 so the loop will never run.
ok well im creating a program on vb that controls leds the vb program generates a 5bit binary number which i have then ported to arduino. i then want arduino to read each bit separately and then check if its a 1 or 0
California
You must have missed the thread titled Read this before posting a programming question.
But, to get you started, you should look at a few examples of for loop to see how they work, because I sincerely doubt this piece
is doing what you think it's doing.
« Last Edit: February 28, 2013, 09:29:21 pm by Arrch » Logged
Rome, Italy
Start by correcting this typo, it would make some progress. Then repost the code and tell us what you expect from it and what you got.
for ( counter=0; counter < 5; counter++) {
