Topic: Read float from SD card with Fat16 Lib (Read 2063 times) previous topic - next topic
maxbot
Hello guys, I Need your help !
I use the fat16 lib to store float values (temperatures) to a SD Card. One per line and with 2 fractional digits.
Now I want to read them out again and store them into float variables.
I use this code to read out data in general:
Code: [Select]
* This sketch reads and prints the file
* PRINT00.TXT created by fat16print.pde or
* WRITE00.TXT created by fat16write.pde
#include <Fat16.h>
#include <Fat16util.h> // use functions to print strings from flash memory
SdCard card;
Fat16 file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char*  str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode) {
    PgmPrint("SD error: ");
    Serial.println(card.errorCode, HEX);
  while(1);
void setup(void) {
  PgmPrintln("type any character to start");
  while (!Serial.available());
  // initialize the SD card
  if (!card.init()) error("card.init");
  // initialize a FAT16 volume
  if (!Fat16::init(&card)) error("Fat16::init");
  // open a file
  if (file.open("PRINT00.TXT", O_READ)) {
    PgmPrintln("Opened PRINT00.TXT");
  } else if (file.open("WRITE00.TXT", O_READ)) {
    PgmPrintln("Opened WRITE00.TXT");
  } else{
    error("file.open");
  // copy file to serial port
  int16_t n;
  uint8_t buf[7];// nothing special about 7, just a lucky number.
  while ((n = file.read(buf, sizeof(buf))) > 0) {
    for (uint8_t i = 0; i < n; i++) Serial.write(buf[i]);
   PgmPrintln("\nDone");
void loop(void) {}
So how can I convert the uint8_t Array to a float variable ?
Thanks for your help :)
Nick_Pyner
Code: [Select]
 /code]
[/quote]
Why is there an array? You should be able to simply write the floats to the card and then read them straight back.
[code]//  Read temps off SD.
#include <SD.h>
File myFile;
  Serial.print("Initializing SD card...");
   pinMode(53, OUTPUT);// pin 10 on Uno
  if (!SD.begin(4)) {
    Serial.print("initialization failed!");
    return;
  Serial.println(" done.");
  myFile = SD.open("log.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Checking the file, no write...");
    myFile.close();
    Serial.println("done.");
    Serial.println("error opening");
  myFile = SD.open("log.txt");// re-open the file for reading:
  if (myFile) {
    Serial.println("log.txt:");
    while (myFile.available()) {// read until EOF
    Serial.write(myFile.read());
    myFile.close();
    Serial.println("error opening log.txt");
[/code]
maxbot
Code: [Select]
 /code]
[/quote]
#include <SD.h>
File myFile;
  if (!SD.begin(4)) {
    return;
  if (myFile) {
    myFile.close();
  if (myFile) {
    myFile.close();
[/code]
Thanks Nick_Pyner, but I finally managed it on my own.
Just a single conversion to double was required. I am not using the official SD lib because the Fat16lib is much smaller and for my Project, code size is a very important aspect.
Code: [Select]
while((file.read(buf, sizeof(buf)) >0) && (count <= 3071)){
    double temp = atof((char*)buf);
