Topic: Getting simple data from a website (Read 1 time) previous topic - next topic
tomvo
Mar 01, 2013, 11:23 am Last Edit: Mar 01, 2013, 11:28 am by tomvo Reason: 1
I'm trying to get some data from a website : myip.dnsdynamic.org
just want the IP address.
i have found a thread but it doesn't work
the only thing i'm getting in my serial monitor is :
connecting...
connected
disconnecting.
so there is a connection, but it fails to give me  the IP-address.
DHCP worked, for testing ik tried it with a manual IP, gateway, subnet.... but still no result...
tnx in advance
the code i'm using is :
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char serverName[] = "/myip.dnsdynamic.org" ;
// Initialize the Ethernet client library
EthernetClient client;
  while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 // start the Ethernet connection:
 if (Ethernet.begin(mac) == 0) {
   Serial.println("Failed to configure Ethernet using DHCP");
   // no point in carrying on, so do nothing forevermore:
   for(;;)
 // give the Ethernet shield a second to initialize:
 Serial.println("connecting...");
 // if you get a connection, report back via serial:
 if (client.connect(serverName, 80)) {
   Serial.println("connected");
   // Make a HTTP request:
  client.println("GET / HTTP/1.0"); // didnt work
  client.println("GET /myip.dnsdynamic.org HTTP/1.0");
  client.println("Host: myip.dnsdynamic.org");
  client.println();
 else {
   // if you didn't get a connection to the server:
   Serial.println("connection failed");
 // if there are incoming bytes available
 // from the server, read them and print them:
 if (client.available()) {
   char c = client.read();
   Serial.print(c);
 // if the server's disconnected, stop the client:
 if (!client.connected()) {
   Serial.println("disconnecting.");
   client.stop();
   // do nothing forevermore:
   for(;;)
SurferTim
This client code works for me.
http://playground.arduino.cc/Code/WebClient
zoomkat
Some modified client code using the below link.
http://checkip.dyndns.com/
Code: [Select]
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
void setup(){
    while(true);
  Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    client.println("GET / HTTP/1.0"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("==================");
  client.stop(); //stop client
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
tomvo
tnx zoomkat & SurferTim
this works, my serial output looks like this
connected
HTTP/1.1 200 OK
Content-Type: text/html
Server: DynDNS-CheckIP/1.0
Connection: close
Cache-Control: no-cache
Pragma: no-cache
Content-Length: 105
<html><head><title>Current IP Check</title></head><body>Current IP Address: 209.121.24.86</body></html>
disconnecting.
do you know if its possible ( i'm sure it is, but don't know how  ) to only get the Ip address out this output?
tnx Tom
bobert0670
Here is a sample that I wrote to read the current temperature of my thermostat.  It has the same basic functionality you are looking for.
Code: [Select]
  if (Get.check() ==1){
    if (!Client.connected())
      Tstatconnect();
    if (Client.connected())
      gtemp();
      Get.interval(60000);
  if (Client.available() > 0)
    ValidDataFound = true;
    ValidDataFound &= Client.find("{");
    ValidDataFound &= Client.find(":");
    DataValueFloat = Client.parseFloat();
    ValidDataFound &= Client.find("}");
    while (Client.available() > 0) Client.read();        //flush the input buffer manually, since the flush() function now only waits for the write buffer to clear.
    if (ValidDataFound)
      Serial.print("Valid Data Found. Value = ");
      Serial.println(DataValueFloat);
            Tstatstop();
      Serial.println("Invalid Data");
      Tstatstop();
} // END OF LOOP
The basic parsing is found in here...
Code: [Select]
zoomkat
Quote
For a small returned string you can capture the string and parse it. You could find the : location in the string and the following < location, and then capture the the IP address that is between these two characters. For large returns there is a library call ed textfinder.h that can be used.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
