Topic: KSduino (Read 7127 times) previous topic - next topic
ksduino
Let me introduce our new Project - KSduino: http://ksduino.org
We have designed this service to connect your Arduino microcontroller(s) to the KSduino device network for free. You may connect your device through Internet to KSduino server and monitor & control Arduino parameters at KSduino.org web site. For more information you can read our Welcome article (http://blog.ksduino.org/post/37480815224/welcome-to-ksduino) or start from home page http://ksduino.org
Best regards,
Kirill Scherba
The founder and main developer of KSduino project.
spumanti
Looks really interesting.
Is there any rate limit for this service?
Looking at the data in some of the public views, shows updated data at least every second, which is very fast for an online service.
Will try it out as soon as I have a chance!  :)
ksduino
Thank and welcome!
It may be faster than 1 in sec, look at http://ksduino.org/?devices&device_parameter_id=9 for example it sends 10 values per secont. We use UDP to send & receive packets and Arduino and KSduino can send & receive more but the KSduino is public online service and I don't recomend increase your speed more then 1 value per second in your tests.
zveno61
Hi Kirill!
I started studying Ksduino. I use the example Arduino UNO and two temperature sensors ds18b20. I pass parameters of temperature every second. Can I increase the frequency of sending? For example, two or four items per second for the other parameters, and continue to transmit the temperature once a second? Will your service to process packets at this rate? My controller is Arduino UNO ID 3303  https://ksduino.org/?devices&device_id=3303.
Regards, Andre.
ksduino
Yes, you can try your experiments! See the documentation (http://ksduino.org/?docs) and help (http://help.ksduino.org) pages for additional information.
zveno61
Ok. Thank you. later I will try to/
ksduino
See article 'How KSduino works' for additional info:
http://blog.ksduino.org/post/37944359140/how-ksduino-works
ksduino
New How to 'How to send parameters from one to another Arduino Device?' was added: http://help.ksduino.org/post/38261558718/how-to-send-parameters-from-one-to-another-arduino
ksduino
Read new article to Connect your Arduino with ENC28J60 Ethernet Shield to KSduino:
http://blog.ksduino.org/post/38636723785/ksduino-can-connect-your-arduino-with-enc28j60
ksduino
See Article about Using UDP protocol with Arduino
http://blog.ksduino.org/post/39659066923/using-udp-protocol-with-arduino
ksduino
The INFOrmer Page was added to KSduino: http://ksduino.info
ksduino
There is some new advice of connection your Arduino to the KSduino device network: http://ksdu.in/o/34
The KSduino INFOrmer page http://ksduino.info becomes more complete. You can use Saved Buttons (saved actions) to control your device from your INFOrmer page. You can allso add share buttons at your INFOrmer page. See the http://ksdu.in/o/35 as example and Blink it :-)
[this function is allowed for registered KSduino users only]
ksduino
The the KSduino forum was opened today, so you can discus your KSduino projects:
http://forum.ksduino.org/
Look Terry King's blog page about his KSduino project:
http://forum.ksduino.org/index.php?topic=5.0
http://arduino-info.info/blog/?p=4
ksduino
New article "Multitasking and real time systems at Arduino" was added to KSduino blog: http://ksdu.in/o/47
