Author Topic: Speed of Shiftin command?  (Read 197 times)
Hey guys,
I was just wondering at how long it takes for shiftin to complete one cycle (as in one cycle being the command reading in one byte). I have 20 inputs, therefore needing 3 4021 chips (8*3 > 20).
Realistically, I could do with the shiftin being <10ms so that I can call a shiftin every 10ms.
Also, while shiftin is happening, is the arduino able to do other things?
Cheers,
Valencia, Spain
Hey guys,
No problem. It's probably hundreds of times faster than that.
No.
Perfect answers!
Thanks.
Boston area, metrowest
Online Online
You could also do this with SPI.transfer, will be a lot faster:
digitalWrite(ssPin, LOW);  // if you need CS with the part you are using.  can also direct port manipulation for more speed
incomingByte = SPI.transfer(0); // where 0 is data that will get clocked out on MOSI pin while data is clocked in on MISO pin at the same time.
digitalWrite(ssPin, HIGH);
