Topic: Sending String over serial with two arduinos (Read 933 times) previous topic - next topic
svermigo
Mar 01, 2013, 03:45 pm Last Edit: Mar 01, 2013, 03:52 pm by svermigo Reason: 1
Hello, I hope im in good section :),
I have some troubles to get working serial communication between two arduinos. I found really nice library, where you can create a struct, it will be serialized and sent over serial. It should be deserialized and give you good results. But it doesnt work for me. When I use just integers in struct, works everything fine, but when I change to String, it doesnt work anymore. I think the problem will be probably in size of whole struct, but im not sure, im quite new in arduino.
Can anyone help me how to get around it and send strings between these two arduinos?
transmitter:
#include <EasyTransfer.h>
EasyTransfer ET;
struct SEND_DATA_STRUCTURE{
 String data;
 String filename;
//give a name to the group of data
SEND_DATA_STRUCTURE mydata;
#include <Wire.h>
void setup(){
 Serial1.begin(9600);
 ET.begin(details(mydata), &Serial1);
 mydata.data = "text dataaaa :-)";
 char temp[] = "file.txt";
 mydata.filename = temp;
 ET.sendData();
 delay(5000);
receiver:
struct RECEIVE_DATA_STRUCTURE{
 String data;
 String filename;
RECEIVE_DATA_STRUCTURE mydata;
EasyTransfer ET;
 if(ET.receiveData()){
   Serial.println(mydata.data);
   Serial.println(mydata.filename);
EDITED:   I dont need to use this library, if there is another solution :)
zoomkat
Not sure what the struct thing is, but sending strings should be fairly easy. Have you tested sending strings using the serial monitor?
PaulS
Your struct does not contain two strings. It contains two Strings. Strings are far different beasts from strings. Until 1.0.4 is released, they are to be avoided.
Replace the Strings with strings, and the transfer will work.
svermigo
when I replace it, I got this error .. error: 'string' does not name a type
Do I need import any library?
Thanks
PaulS
Of course not. The term string is a shorter way of saying "NULL terminated array of chars".
No. You simply need to use a char array.
svermigo
I have tried that allready, but I didnt find out, how to do it :( ..
  char data[9];
mydata.data = "file.txt";
gives me  - error: invalid array assignment
so I tried
  char data[9];
mydata.data = temp;
same error - error: invalid array assignment
I also tried
  char data[9];
mydata.data = &temp[0];
error: incompatible types in assignment of 'char*' to 'char [9]'
Every time, Im getting error on the last row ..
I have found about 100 ways how it doesnt work :( .. can you try to give me one working example please ? :(
PaulS
Maybe you need to get a book on C, and learn HOW to work with strings. The strcat() and strcpy() functions do what you have tried every which way but correctly to do.
svermigo
Thanks
