Author Topic: Flash 4  (Read 379 times)
bonjour barbudor, un peu novice dans le monde des arduino je rencontre un probleme similaire lors de la compilation projet identique...sauf que j'utilise une carte MEGA2560 Rev3. arduino 1.0.1 je rencontre une série d'erreur lors de la compilation lie a la bibliotheque FLASH version 4.
je n'est fait aucune modif sur le fichier print.h...au passage faut-il finalement modifier le fichier ?????
une petite idée de ce qui pourait causer toutes ces "insultes"????
In file included from sketch_feb28a.cpp:68:0:
/usr/share/arduino/libraries/Flash/Flash.h:68:23: error: ‘prog_char’ does not name a type
/usr/share/arduino/libraries/Flash/Flash.h:68:34: error: ISO C++ forbids declaration of ‘arr’ with no type [-fpermissive]
/usr/share/arduino/libraries/Flash/Flash.h:79:9: error: ‘prog_char’ does not name a type
/usr/share/arduino/libraries/Flash/Flash.h:91:9: error: ‘prog_char’ does not name a type
/usr/share/arduino/libraries/Flash/Flash.h: In member function ‘size_t _FLASH_STRING::length() const’:
/usr/share/arduino/libraries/Flash/Flash.h:71:21: error: ‘_arr’ was not declared in this scope
/usr/share/arduino/libraries/Flash/Flash.h: In member function ‘char* _FLASH_STRING::copy(char*, size_t, size_t) const’:
/usr/share/arduino/libraries/Flash/Flash.h:76:20: error: ‘_arr’ was not declared in this scope
/usr/share/arduino/libraries/Flash/Flash.h: In member function ‘char _FLASH_STRING::operator[](int) const’:
/usr/share/arduino/libraries/Flash/Flash.h:86:30: error: ‘_arr’ was not declared in this scope
/usr/share/arduino/libraries/Flash/Flash.h: At global scope:
/usr/share/arduino/libraries/Flash/Flash.h:181:29: error: ‘prog_char’ does not name a type
/usr/share/arduino/libraries/Flash/Flash.h:181:41: error: ISO C++ forbids declaration of ‘arr’ with no type [-fpermissive]
/usr/share/arduino/libraries/Flash/Flash.h:201:9: error: ‘prog_char’ does not name a type
/usr/share/arduino/libraries/Flash/Flash.h: In constructor ‘_FLASH_STRING_ARRAY::_FLASH_STRING_ARRAY(const int**, size_t)’:
/usr/share/arduino/libraries/Flash/Flash.h:181:62: error: class ‘_FLASH_STRING_ARRAY’ does not have any field named ‘_arr’
/usr/share/arduino/libraries/Flash/Flash.h: In member function ‘_FLASH_STRING _FLASH_STRING_ARRAY::operator[](int) const’:
/usr/share/arduino/libraries/Flash/Flash.h:188:26: error: ‘_arr’ was not declared in this scope
/usr/share/arduino/libraries/Flash/Flash.h: In member function ‘virtual void _FLASH_STRING_ARRAY::print(Print&) const’:
/usr/share/arduino/libraries/Flash/Flash.h:194:25: error: ‘_arr’ was not declared in this scope
un grand merci d'avance..
Ile-de-France (92 sud), France
Les erreurs se produisent durant la compilation de ton sketch. Elles sont probablement dues a ton sketch et pas à Flash4.
Sans ton sketch, peut rien faire
Et puis ici c'est un sujet a propos de Web Serveur, pas de Flash4 smiley-wink
Barbuduino: Arduino sur Breadboard & VinciDuino: Clone Leonardo // WR703: Mini-routeur hacké // LauchPad MSP430 et Stellaris // Panda II Arduino-like .NetMF sous VisualC#
RTFC: Read That F.....g Code / RTFD: Read That F.....g Doc / RTFDS: Read That F.....g DataSheet / RTFS: Read That F.....g Schematic / Wot da ya wanna D.I.Y. today ?
France
Arduino Hacker
Bonjour,
Ça s'en l'include de <avr/pgmspace.h> oublié quelque pars.
Ou une erreur de syntaxe avant l'include de <Flash.h>.
Des news, des tuto et plein de bonne chose sur http://skyduino.wordpress.com !
et l'html 5 ??
France
Arduino Hacker
et l'html 5 ??
Quel est le rapport avec l'HTML5 ?
J'ai beau chercher j'en trouve pas ... smiley-roll
Qu'on soit bien d'accord :
La librairie arduino "Flash" c'est pour stocker des données en mémoire flash, pas pour faire du Flash (le langage d'adobe).
mort de rire ! ceci explique cela ! quand j'ai vu écrit flash 4 j'ai pensé de suite a l'intégration de la version opensource du player adobe. smiley-wink
France
Arduino Hacker
Oui mais non, faut pas rêver smiley-wink
