Topic: Bizarre serial input behavior - Input from experienced users appreciated! (Read 4443 times) previous topic - next topic
retrolefty
The professor is looking for function, not form or good practice
Whoa.
That was my first impression also, many Profs I've known would rather talk about how something should be accomplished rather then do anything constructive to help make it happen.  ;) Maybe it's a mechanical engineering prof, they seem to be much better grounded then others.
Lefty
PaulS
Quote
Spin control!!! Struggling!!!
Yes, that describes you perfectly.
nickgammon
I would like everyone in this thread to stick to answering technical questions and not bicker or insult each other.
Thank you.
Otherwise I'll lock it.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
GoForSmoke
Strong, bulletproof if possible, highly responsive User I/O -is- function.
The form you use is up to you. I know what works for me from long working experience so I can share that. Try it both ways and then try another, see what's easier and what's harder and most important, Why.
I think you should use parseInt() if your prof couldn't give a fig about your code. You'll save time and effort on your grade. The grade that you want what kind of help for? Not general advice?
You'll know if your prof cares about your code by what he does as the User. Will the User be required to enter only legal inputs? What if the User enters ABC? If your prof is required to only enter up to 3 digits always then you can get away with not coding error handling which as a pro you can't because in the Real World, users make bad entries but as a student what will you get? A test of function with or without unexpected, human, input?
The spec says using serial monitor the user must do X and see Y. Nothing about how serial monitor is set up. Set it up and close it, next time it opens the setting is still the same. Then have your user do what is required and your code do what it should.
But I'll just stop trying to help. I don't know enough.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
