Topic: PROBLEM IN UPLOADING (Read 565 times) previous topic - next topic
Bleyk
  GSM Send Sketch for Arduino
  Initializes GSM Module and sends an SMS to recipient
  The circuit:
  *Arduino pin 0 (RX) - GSM Module (TX)
  *Arduino pin 1 (TX) - GSM Module (RX)
  Created 2010
  by Meann Zabanal
  Modified
  by John for GSM Shield testing
char Rx_data[50];
unsigned char Rx_index = 0;
int i = 0;
char msg[160];
int sig;
  Serial.begin(38400);
  initGSM();
  send_msg("09167029131", "Arjen Garcia");
  //none
void send_msg(char *number, char *msg)
  char at_cmgs_cmd[30] = {'\0'};
  char msg1[160] = {'\0'};
  char ctl_z = 0x1a;
  sprintf(msg1, "%s%c", msg, ctl_z);
  sprintf(at_cmgs_cmd, "AT+CMGS=\"%s\"\r\n",number);
  sendGSM(at_cmgs_cmd);
  delay(100);
  delay(100);
  delay(100);
  sendGSM(msg1);
  delay(100);
void sendGSM(char *string){
  Serial.write(string);
  delay(90);
void clearString(char *strArray) {
  int j;
  for (j = 100; j > 0; j--)
    strArray[j] = 0x00;
void send_cmd(char *at_cmd, char clr){
  char *stat = '\0';
  while(!stat){
    sendGSM(at_cmd);
    delay(90);
    readSerialString(Rx_data);
    stat = strstr(Rx_data, "OK");
  if (clr){
    clearString(Rx_data);
    delay(200);
    stat = '\0';
void initGSM(){
  send_cmd("AT\r\n",1);
//  send_cmd("ATE0\r\n",1); // Turn off automatic echo of the GSM Module
  send_cmd("AT+CMGF=1\r\n",1);         // Set message format to text mode
  //Sucess
  Serial.println("Success");
void readSerialString (char *strArray) {
  if(!Serial.available()) {
    return;
  while(Serial.available()) {
    strArray = Serial.read();
    i++;
PLEASE I NEED HELP !!!!!!!!
AFTER UPLOADING IT ALWAYS SAYS "avrdude: stk500_getsync(): not in sync: resp=0x1c"
HELP ME PLEASE !!!!!!!!!!!!! =( =( =( =( =( =( =( =( =(
Chaul
Can you upload anything to that board? Even just the blink example? Or is just with this wiring and this code? I'm asking because of some of my uploading problems were related to me plugging some IRQ line into the wrong microcontroller pin. Sometimes Windows would just say the device has malfunctioned and it would get disconnected, and other times Arduino IDE would pass along some sync error.
Please don't use all caps.
astrofrostbyte
Like Chaul said , go back to basics, just bare board, simple script.  make sure you have the correct board type selected,  no other devices are competing/locking the serial port.
UKHeliBob
Put your code in code tags (#) and STOP SHOUTING !
PeterH
Apart from the basics which have already been suggested, the Installation and Troubleshooting section might be a more appropriate place for this thread so you might get more help there. Just ask a moderator to move it in that case.
