Topic: ENC28J60 + Arduino Nano Problem (Read 1 time) previous topic - next topic
Vorax
Recently, my ENC28j60 breakout Board arrived. Then, I started downloading libraries, testing examples and only a few (and simple) codes work. I.e :
Code: [Select]
#include "etherShield.h"
#include "ETHER_28J60.h"
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24};
static uint8_t ip[4] = {192, 168, 1, 15};
static uint16_t port = 80;
ETHER_28J60 ethernet;
  ethernet.setup(mac, ip, port);
  if (ethernet.serviceRequest())
    ethernet.print("<H1>Hello World</H1>");
    ethernet.respond();
  delay(100);
Success!
BUT, this one for i.e. (from the same library) don't work!
Code: [Select]
int outputPin = 6;
ETHER_28J60 e;
  e.setup(mac, ip, port);
  pinMode(outputPin, OUTPUT);
  char* params;
  if (params = e.serviceRequest())
    e.print("<H1>Web Remote</H1>");
    if (strcmp(params, "?cmd=on") == 0)
      digitalWrite(outputPin, HIGH);
      e.print("<A HREF='?cmd=off'>Turn off</A>");
    else if (strcmp(params, "?cmd=off") == 0)
      digitalWrite(outputPin, LOW);
      e.print("<A HREF='?cmd=on'>Turn on</A>");
    e.respond();
I'm using IDE 1.0.3 but tried with 0022 and nothing!
DHCP examples from Ethercard Library returns ''DNS failed''
I don't know if helps but i realized that the SCK pin stuck HIGH when program dont work. (due to the led connected on pin 13)
Thanks!
