Topic: Timer Program (Read 820 times) previous topic - next topic
amiro62
Hi all,
This Arduino stuff is great and as poke my interest after reading a lot of stuff that people as done with, one of them is a fellow in Australia who as done some coding for flightsim. I'm working on this for my cockpit stuff.
My son is in paintball and airsoft stuff and I came across this code for the airbomb. I know this is an old code but I just need a little help to add or fix part of the code as I'm also a newbie.
I got the code to work the way I want and with the hardware that I have, screen, lights, sound and keypad.
Only flaw that I cant seem to be able to fix is when the timer is counting down and I press a key the timer stop and if I only press 1 to 3 keys it stays like that forever until I press 4 keys, then it will show either it is wrong or defused the way it is supposed to.
In a game this is not good as one only have to push a key and the bomb is frozen in time.
The timer should either keep on going or if no inputs is keyed in a set of time like (4 or 5 sec) then the timer should resume automatically.
In the code it mention about pause the timer effectively I think it's too effective!! lol :D
Anyway here is what I got as far as code goes (REMEMBER I'M ONLY A NEWBIE) lol
The full file is attached.
 lcd.clear();
 lcd.print("Enter Code: ");
 lcd.cursor();
 key = keypad.getKey(); // get the key once per this loop
 if (key != NO_KEY) {
   lcd.setCursor(0, 1);
   lcd.print("           ");
   lcd.setCursor(6, 1);
   while (currentLength < 4) {
     // here, we take the key that broke us into this "if" statement, instead of discarding it. this also pauses the timer, effectively.
     if (key != NO_KEY)
     { // redundant for the first loop, but necessary for every next character
       lcd.setCursor(currentLength + 5, 1);
       lcd.print(key);
       entered[currentLength] = key;
       currentLength++;
     else delay(10);
     key = keypad.getKey(); // get the key every time "while" loops
   if (memcmp(entered,password,4) == 0) { // shortcut to compare an array of bytes, use memcmp(A, B, length), will return 0 if match.
     lcd.noCursor();
     lcd.clear();
     lcd.print(" Defused ");
     digitalWrite(LED_RED, HIGH); // sets the red LED on
     digitalWrite(LED_GREEN, HIGH); // sets the green LED on
     delay(4000);
     tone(9,1200, 2000); //
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("Bomb Rebooting");
     lcd.setCursor(0,1 );
     lcd.print("Have a nice day!");
     currentLength = 0;
     digitalWrite(LED_RED, LOW); // sets the red LED off
     digitalWrite(LED_GREEN, LOW); // sets the green LED off
     delay(4000); // hold that on screen for 2.5 seconds
     lcd.clear();
     currentLength = 0;
     void (*softReset) (void) = 0; //declare reset function @ address 0
       softReset();
     setup();
   else {
     lcd.noCursor();
     lcd.clear();
     lcd.print(" Wrong ");
     tone(9,110, 2500);
     lcd.print("Penalty -2:00"); // Display time penalty
     if (timerSeconds > 120) timerSeconds -= 120;
     else timerSeconds = 1; // will trigger BOOM next cycle
     currentLength = 0;
     delay(2500); // hold that on screen for 2.5 seconds
     lcd.clear();
 timer(); // prints current time on screen, checks for "go off" time, holds loop for 1 second
void timer() {
 lcd.setCursor(0, 1); // sets cursor to 2nd line
 lcd.print("Timer: ");
 lcd.print(timerSeconds / 60); // integer number of minutes on clock
 lcd.print(":");
 lcd.print(timerSeconds % 60); // mod 60; gives us number of seconds outside of 60sec/min
 delay(950); // hold us here for 0.950 seconds
   digitalWrite(LED_RED,!digitalRead(LED_RED)); // toggle the red LED once a second
 tone(9,800, 250); // play bleep for 50ms
 delay(50); // and there's the rest of that 1 second (not counting LCD delay)
 timerSeconds--;
 if (timerSeconds == 0) bombomb();
HazardsMind
Are you using the arduino itself to do the timer, and not a RTC? Your in a while loop and you will remain in there until the condition is met. So you will only get out when you have all 4 digits. If you want the counter to continue counting during this while loop, you will need to get a RTC.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
amiro62
At the moment I'm using an Arduino mega but I plan to use a UNO later to many inputs with the Mega for this little project and I will use it for my flight stuff later when I puts it together.
How much problem will it be to add the Real Time Clock to it if it's needed, i'm guessing that the arduino only carry out one task at a time is that why the RTC is needed?
Thanks for the fast response!!!
Mario
HazardsMind
It shouldn't be too much of a problem, but it depends on the number on pins your using. I cant open your code file here at work, so I don't know exactly what pins are in use. My advise would be to do some research on RTC's, and try to see if it will work with what you have already.
My GitHub:
amiro62
Hi, Hazard
right now these are the pin's I'm using on the Arduino,
LCD = pin 7,8,10,11,12,13,GND,5v
Buzzer = pin 9,GND
Leds = pin 5,6,5v
Keypad = pin 2,14,15,16,17,18,19,5v
so only pin 0,1,3,4,20,21 and analogin is not being used. (if that can help!! lol)
Mario
AWOL
One particular moderator put a lot of time and effort into writing and posting the sticky threads at the top of each section of the forum.
Please show your appreciation by reading them before posting
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
HazardsMind
My GitHub:
Cookies
#7
Mar 03, 2013, 04:57 pm Last Edit: Mar 03, 2013, 04:59 pm by Cookies Reason: 1
Theres no need for an RTC. In timer() remove the delays and use millis() to see if a second has passed and code should be ran or not, like THIS. Then put a call to timer() in the while loop. Ideally you should get rid of that while loop and just set a variable that decides which part of the code to run since loop() is already called from a while loop.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
