Topic: 64 analog reads (Read 3012 times) previous topic - next topic
Marvinfly
Hello,
I'm looking to read about 64 Analog temp sensors every loop. I'm not sure if any of the arduinos are capable of this due to limited analog inputs.
Do you know of anything that could handle this?
thanks
cmiyc
"Every loop" isn't a measure of time.
Depending on how fast you need to read each sensor, you may have to design a circuit with multiplexers feeding one or more A/D converters.
MaJiG
You will need external analog multiplexers like the ADG1606 here:http://www.analog.com/en/switchesmultiplexers/multiplexers-muxes/adg1606/products/product.html
Four of these hooked up to analog input pins, and a few digital output pins for control and you can read 64 voltages.
cmiyc
Don't over look the fact that the ATmega chip only has 1 (or 2 depending on the chip) A/D converters.  The analog pins on the Arduino board are connected to an internal mux.
Keep that in mind when designing your external mux.
MikMo
4 CD4067 multiplexers will give you 64 analog inputs.
How often do you need to read them?
zoomkat
The sparkfun 4067.
https://www.sparkfun.com/products/9056
MikMo
If 48 was enough you could use this:
https://www.sparkfun.com/products/9832
It uses 3 4067 muxes
