Topic: Sparkfun Keypad Defective?? Pictures included (Read 4122 times) previous topic - next topic
mpick67
Mar 02, 2013, 06:40 pm Last Edit: Mar 02, 2013, 06:49 pm by mpick67 Reason: 1
I'm working on a larger project that uses a keypad for input. Before I add it to my project I tested it separately to see if it worked. I followed this guide:
http://www.instructables.com/id/Using-the-sparkfun-12-Button-keypad-with-the-ardu/?ALLSTEPS
This is my setup:
Do you see anything wrong with this setup?
I don't get any information printed to my serial window when I press a button. Thanks, Mike
Erdin
#1
Mar 02, 2013, 06:59 pm Last Edit: Mar 02, 2013, 07:03 pm by Erdin Reason: 1
I didn't check every wire in the photos, but I can't see what's wrong.
Can you use a multimeter, and with the keyboard not attached to the Arduino. To see if pressing a key causes a combination of wires to connect ?
Can you add a serial print to the setup() function, so you know the serial communicaton is okay ?
Serial.println("Hello");
Zapro
Those solder joints looks very suspicious!
Is the solder even contacting the pads below ? It almost looks like there is no pad underneath the solder, almost like someone ripped it clean off...
Please take a better picture from a different angle of this
// Per.
mpick67
// Per.
I tried to be very careful when I was soldering, and I tried pulling on the wires connected to the keypad to see if they were lose, but they seemed to be very secure. Here are the pictures you requested.
HazardsMind
#4
Mar 12, 2013, 05:42 pm Last Edit: Mar 12, 2013, 05:45 pm by HazardsMind Reason: 1
If you touch pins 5 and 8 on the arduino, do you get an output?
Why are you using pull down resistors? Take them out.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
mpick67
I resoldered all the connections so I'm just about 100% sure it's not my connections that are bad. I touched pins 5 and 8 but nothing happened. The reason I was using the resistors was because I was following this tutorial: http://bildr.org/2011/05/arduino-keypad/
HazardsMind
#6
Mar 12, 2013, 08:11 pm Last Edit: Mar 12, 2013, 08:13 pm by HazardsMind Reason: 1
You won't need external resistors or diodes because the library uses the internal pullup resistors and additonally ensures that all unused column pins are high-impedance
http://playground.arduino.cc//Code/Keypad
Also if you download the Keypad library, why not just use one of the other examples to test your keypad?
My GitHub:
mpick67
I'm thinking it must be my arduino uno that's the problem. I tried the examples but none of them seem to work. I connected my multimeter to pins 2 and 3 and read -.005 volts and when I pressed button 1 the multimeter instantly went to zero volts. So do you think my arduino is bad?
wizdum
You want to be measuring resistance, not voltage.
mpick67
I just went through and tested all of the pins on my arduino with a servo motor to check and see if my arduino was broken by chance. All the pins work (1-13). And my serial link is good. This is really aggravating.  :smiley-eek: this silly keypad is holding up my entire project.
HazardsMind
I think I now see what your problem is. I just tried to make my own keypad password, with a changeable master password and once I change the master, my '1' button does not work. Even in the serial monitor, it won't work. I don't understand what changed, but I think your having the same issue, however yours just wont work at all.
This is very strange.
Now if it was just the keypad, you should get a reading when you touch pins 5 and 8, but even then, nothing happened.
It must be a bug in the library.
My GitHub:
HazardsMind
I solved my problem, and I think I spotted yours. Your resistors, are they going to GND or V+?
My GitHub:
