Topic: ATtiny..... Is it really that simple? (Read 3443 times) previous topic - next topic
Peter_I
So many lovely gizmoes just waiting to be bought and played with!
(But I can keep the buyer's frenzy at bay until I need them.... should be a day or two at least!)
Some better pictures:
"Nothing is foolproof to a sufficiently talented fool"
mrburnette
Yes. Just as easy as that.  I find in standalone projects I use far more than ATMega uC's. With the bonus they are lighter, smaller, cheaper as well as simpler...
Adafruit sells a ZIF shield (you can easily clone this) for the UNO and I have modified it for 328P and t85P:
http://www.flickr.com/photos/77727388@N06/7119371109/in/photostream
Changing the jumper and connecting ground (2 separate tasks for chip safety... just in case!) allows either uC to be burned.  It is quick, easy, the sacrifice of a real Arduino UNO, but well worth the $22 price.
ON economics, in 25 Qty, the t85's are under a $1, varies from about $0.85 to $0.99 from Newark.  The same 25 qty of 328P-PU will run about $1.99 so the dollar economics are 2::1 in favor of the smaller chip.  However, I have (except for size and power requirements) simply settled on the 328P because of the additional RAM and flash space.  This along makes it easy to create your own library set to link against and be not-too-concerned about flash or RAM issues.
Also, I have 2 MiniPro's hung off of very short USB cables that I use for programming.  Code that runs in the Arduino Mini environment is nearly guaranteed to run on a naked 328P.  Standardizing on the larger chip is a $1 silicon penalty that is most often the better approach (excepting small size and flea-power requirements.)
- Ray
