Topic: Questions with IR remote (Read 2971 times) previous topic - next topic
tomyhu1995
I want to use my arduino UNO to make a decode device. I found an example code and a some steps which can teach me how to build. In those steps, it told me that I need to download a folder called IRremote and install it in this route /Users/username/Documents/Arduino/libraries.
When I finished write the coding and tried to verify, Arduino IDE said that 'IRrecv' does not name a type.
The following is the code I wrote
#include<IRremote.h>
const int irReceiverPin = 2;
IRrecv irrecv(ivReceiverPin);
decode_results results;
  irrecv.enableIRIn();
  if (irrecv.decode(&results){
    Serial.print("ircode");
    Serial.print(results.value, HEX);
    Serial.println(results.bits);
    irrecv.resume();
The following is the message which came from arduino IDE
/Users/TommyHu/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=103 -I/Users/TommyHu/Downloads/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Users/TommyHu/Downloads/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard /var/folders/40/qp_yf07j11z_nb9qwcs2fgd40000gn/T/build6216189189652123984.tmp/sketch_mar03a.cpp -o /var/folders/40/qp_yf07j11z_nb9qwcs2fgd40000gn/T/build6216189189652123984.tmp/sketch_mar03a.cpp.o
sketch_mar03a.ino:2:21: warning: IRremote.h: No such file or directory
sketch_mar03a:6: error: 'IRrecv' does not name a type
sketch_mar03a:7: error: 'decode_results' does not name a type
sketch_mar03a.ino: In function 'void setup()':
sketch_mar03a:11: error: 'irrecv' was not declared in this scope
sketch_mar03a.ino: In function 'void loop()':
sketch_mar03a:15: error: 'irrecv' was not declared in this scope
sketch_mar03a:15: error: 'results' was not declared in this scope
sketch_mar03a:15: error: expected `)' before '{' token
sketch_mar03a:21: error: expected primary-expression before '}' token
sketch_mar03a:21: error: expected `;' before '}' token
My OS: mac os x 10.8.2
Arduino IDE edition: 1.0.3
Arduino board type: UNO
MaJiG
The path "/Users/username/Documents/Arduino/libraries" looks like a Windows path.  Does your Mac use the same file structure?
tomyhu1995
Thanks for your reply.
I copied the route from my arduino IDE.
The photo is what showed on my IDE.
please teach which route is the right one to install folder like IRreomte.
