Topic: Error IRremote (Read 2037 times) previous topic - next topic
LaMega
Mar 03, 2013, 12:33 pm Last Edit: Mar 03, 2013, 04:29 pm by LaMega Reason: 1
Hello guys who knows why I get this error, and what should I do?
I am a Arduino Due.
but when I put Tools -> Board -> Ardino Uno   everything works
I get the same error with  Arduino Due when I put other libraries.
liquidlightning
Post your whole code.
LaMega
Quote
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
String stato;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value);
    if(results.value == 16767525){
    stato = "acceso1";
    digitalWrite(2, HIGH);
    else if (results.value == 16773645) {
    stato = "acceso2";
    digitalWrite(3, HIGH);
    else if (results.value == 16763445) {
    stato = "acceso3";
    digitalWrite(4, HIGH);
    else if (results.value == 4294967295) {
    stato = "mantieniacceso";
    else {
    stato = "spento";
    if(stato == "acceso1"){
    else if (stato == "acceso2") {
    else if (stato == "acceso3") {
    else if (stato == "mantieniacceso") {
    else if (stato == "spento") {
    digitalWrite(4, LOW);
    digitalWrite(3, LOW);
    digitalWrite(2, LOW);
    irrecv.resume(); // Receive the next value
p0fi
I'm not sure but i think the current IRremote Lib will not work with the Due at all.
I'm also searching a way to make it work together by the way, so any help is welcome :)
Gericom
The library seems to use avr specific interrupt functions. It needs to be rewritten to work with Due.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
