Topic: SD Library - Eclipse Compiler Fehlermeldung Ursache? (Read 943 times) previous topic - next topic
Snoops
Mar 03, 2013, 01:09 pm Last Edit: Mar 10, 2013, 11:27 am by Snoops Reason: 1
Hallo,
ich bekomme folgende Fehlermeldungen, wenn ich das SD Beispiel aus der Bibliothek versuche in Eclipse zu "hämmern".
Ich benutze das "baeyens" Pluging für Eclipse (http://www.baeyens.it/eclipse/UsethePlugin.html).
Code: [Select]
Description Resource Path Location Type
'curCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 34 C/C++ Problem
'curCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 38 C/C++ Problem
'curCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 50 C/C++ Problem
'dirFile' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 129 C/C++ Problem
'F_FILE_DIR_DIRTY' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 39 C/C++ Problem
'FAT_FILE_TYPE_CLOSED' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 76 C/C++ Problem
'fileSize_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 55 C/C++ Problem
'firstCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 37 C/C++ Problem
'firstCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 93 C/C++ Problem
'firstCluster_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 95 C/C++ Problem
'flags_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 39 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 25 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 33 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 46 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 74 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 91 C/C++ Problem
'SdFile' has not been declared SdFile.cpp /Test_SD/SD/utility line 129 C/C++ Problem
'SdFile' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 129 C/C++ Problem
'SdVolume' has not been declared SdFile.cpp /Test_SD/SD/utility line 52 C/C++ Problem
'sync' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 75 C/C++ Problem
'type_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 76 C/C++ Problem
'vol_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 34 C/C++ Problem
'vol_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 50 C/C++ Problem
'vol_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 97 C/C++ Problem
'vol_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 102 C/C++ Problem
'vol_' was not declared in this scope SdFile.cpp /Test_SD/SD/utility line 103 C/C++ Problem
expected ',' or ';' before '{' token SdFile.cpp /Test_SD/SD/utility line 130 C/C++ Problem
expected constructor, destructor, or type conversion before '*' token SdFile.cpp /Test_SD/SD/utility line 61 C/C++ Problem
expected primary-expression before 'const' SdFile.cpp /Test_SD/SD/utility line 130 C/C++ Problem
expected primary-expression before 'size' SdFile.cpp /Test_SD/SD/utility line 130 C/C++ Problem
initializer expression list treated as compound expression SdFile.cpp /Test_SD/SD/utility line 130 C/C++ Problem
make: *** [SD/utility/SdFile.o] Error 1 Test_SD C/C++ Problem
SdFat.h: No such file or directory SdFile.cpp /Test_SD/SD/utility line 20 C/C++ Problem
HIer das Beispiel, das die Probleme verursacht:
Code: [Select]
//Do not remove the include below
#include "Test_SD.h"
* Sketch to compare size of Arduino SD library with SdFat V2.
* See SdFatSize.pde for SdFat sketch.
#include <SPI.h>
#include <SD.h>
File file;
  while (!Serial) {}  // wait for Leonardo
  if (!SD.begin()) {
    Serial.println("begin failed");
    return;
  file = SD.open("TEST_SD.TXT", FILE_WRITE);
  file.println("Hello");
  file.close();
  Serial.println("Done");
void loop() {}
Irgendjemand eine Idee wo die Ursache liegt?
Snoops
Hallo,
wirklich niemand der das mal ausprobiert hat bzw. was zur Problemfindung weiß?
uwefed
Mit der Arduino IDE funktioniert der Sketch?
Beim der Arduino IDE bedeutet:
daß die Bibliothek nicht gefunden wurde.
expected ',' or ';' before '{' token weißt auf ein fehlendes Semikolon oder eine geschwungene Klammer zuviel hin.
Sicher ist es fehlt das "//" bei "Do not remove the include below"
Grüße Uwe
Snoops
JA, ist ja ein Arduino Beispiel und mit der Arduino 1.0.3 lässt sich das ohne Probleme kompilieren.
Das "//" war ein cut and paste Fehler.
Ich habe den offizielle SD-Library Ordner in eclipse eingebunden, der ja in der Arduino IDE problemlos spielt.
Was kann den Ursache für die vielen "declared" Probleme sein?
Irgendwie scheint das Problem an der offiziellen SdFile.cpp zu liegen.
Als Warnung komm auch "SdFat.h: No such file or directory", obwohl diese wie SdFile.cpp auch im utility Ordner liegt!?
Gruß
Snoops
uwefed
Quote
Bist Du sicher daß das der richtige Ort ist? Wo sind die anderen Bibliotheken?
Grüße Uwe
Snoops
Eigentlich schon liegt alles im selben Verzeichnis, wo bspw. auch die SPI-Lib liegt.
Habe auch schon mehrmals versucht die SD-Lib neu einzubinden aber das bringt auch keine Abhilfe...
Eclipse Ansicht siehe Anhang...
Gruß
    Snoops
Snoops
Mittlerweile habe ich den Fehler gefunden. In der Library fehlt der Verweis, das die Files in utility Ordner liegen dh. man muss "/utility" bsw. #include <utility/SdFatUtil.h>
bei den Problemfiles in der Library dazuschreiben und schon spielts... :0
