Topic: Effect of Returning from loop() (Read 1 time) previous topic - next topic
If I return from the required loop()   function ,  Does the System automatically re run the function, or will the system stall.
I have a piece of code in a new loop1()  using Scheduler.   The code calls a return; on any config failures.   I would hope the loop1() will just repeat.
Is this a correct assumption?
I believe I got my answer for main.cpp
nt main(void)
#if defined(USBCON)
   for (;;) {
      if (serialEventRun) serialEventRun();
   return 0;
Right.  loop() will get called over and over.  Your new function loop1() will only be called if you call it.  Returning from it will return to wherever you called it from.
|| | ||| | || | ||  ~Woodstock
Ahh. But with the Due, There is a Scheduler library.   This loop1 is a secondary loop. ( Multitasking)
Will this loop be  called again like the Main loop?
Oh, you didn't say Due.  I don't know about Due.
But if it uses that same main.cpp then I would assume no since that main() doesn't ever call anything called loop1().
|| | ||| | || | ||  ~Woodstock
Sorry for not being clear about the Due.
I would hope that the Scheduler library would handle the loop.
I will dig into this.
Thanks for your reply.
The Due has its own forum section.
Would you like me to move this thread there?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Ran some tests at it appears that the secondary loops do in fact repeat  after a return.
