Topic: void and (void) in function declaration (Read 825 times) previous topic - next topic
OptoLcd
Hello,
From a previous topic http://arduino.cc/forum/index.php/topic,66401.0.html
I came across the code segment below and the (void) has stumped me.
I would be grateful if someone would explain the function since I only know the single void declaration.
Thanks in advance.
void (*menu_funcs[NUM_MENU_ITEM])(void) = {
  condition,
  lager,
  ale,
  strike,
  boil
Arrch
It's not a function, It's an array of function pointers. So something like this:
menu_funcs[1]();
Would be the same as this
lager();
AWOL
...and the second void specifies the function takes no arguments.
A bit like me, really.
wildbill
Pointers to functions allow you do some powerful stuff with the opportunity to make your code compact. I've rarely seen them used with the arduino, so you could easily forget what you just saw if it suits you. On the other hand, it's a useful technique to have in your toolbox.
OptoLcd
Thanks all.
"pointers to functions" was the key phrase for Google.
majenko
You're void?
