Loading...
Pages: [1]   Go Down
Author Topic: Solenoid valve.  (Read 539 times)
Offline Offline
Newbie
View Profile
i have a little problem here about solenoid valve 220V AC.
i am using 5v micro controller. i will operate 200V AC solenoid valve operated by 5v micro controller, but i don't know if it will be work properly.
solenoid valve is powered by 220v AC. My question is, can it be change from 220v AC supply to 12v, and how can i make solenoid valve powered by 12v?
Need help here!!! please!  smiley-confuse smiley-confuse smiley-confuse
i forgot. here is the flow chart, it goes like this.
5v Controller -> 12v Relay -> 220v AC(i want this to be 12v)
to protect my controller and my LCD for high Voltage which is 220v AC.
« Last Edit: March 03, 2013, 05:04:39 pm by jhoey19 » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You will need to find a 12V solenoid valve or stick with using a mains-rated relay to control it.
In theory a solenoid valve could have its coil re-wound, but I suspect taking one apart will ruin it...
Logged
Offline Offline
Newbie
View Profile
I would use a solid state relay (SSR) driven by the uC to run the solenoid.  That way you get optical isolation from the mains.  The SSR can be driven by the 5V uC with proper choice of current limiting resistor.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
or just something like the beefcake relay kit from sparkfun (https://www.sparkfun.com/products/10733) for 7.95 and optically isolate it if you wanted to with something like https://www.sparkfun.com/products/314 from sparkfun as well.
or, you could just go with a smaller solenoid valve such as https://www.sparkfun.com/products/10456.  i am using two of these currently in my garden
Logged
Germany
Offline Offline
Jr. Member
Arduino in Visual Studio MODE
View Profile
u can i there use a 12V solenoid valve or use a fuse for ur safty
Logged
Pages: [1]   Go Up
Print
Jump to:
