Topic: motor draws much current - diabling other components? (Read 3530 times) previous topic - next topic
karlok
Yes but I would add extra decoupling.
do you mean I shall use two power supplies ?
- one for the arduino board
- one for the motors
what are good compact power supplies and able to supply much current for the motors?
I am thinking of some rechargable battery charged by the arduino board...
Grumpy_Mike
Quote
Well two power supplies are the ultimate in decoupling but are not essential. You can do more with inductors and capacitors. See the last schematic in this link:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
michinyon
The sagging voltage due to the motor,   and interference from the motor,  are really two separate issues
and you need to consider both of them.
Get a voltmeter or multimeter and see if the voltage drops when you run the motor.
