Topic: How does define work? (Read 1 time) previous topic - next topic
GekoCH
Hy
I got a strange behaviour when I use this code:
#define alt  10000
void setup(){
  Serial.println(alt);
  if (55000 >= (alt * 100)){
    Serial.println("Yes");
  else{
    Serial.println("no");
void loop(){ }
Why Is the Output yes? Since 10000 * 100 is greater then 5500??
Whe I use following code it works:
Instead of *100 I use *100.
#define alt  10000
void setup(){
  if (55000 >= (alt * 100.0)){
  else{
void loop(){ }
I don't get it!!
Andy
AWOL
#1
Mar 04, 2013, 11:23 am Last Edit: Mar 04, 2013, 11:26 am by AWOL Reason: 1
No, it isn't - it is less than zero. (16 bit arithmetic, remember)
Edit: Sorry, not less that zero, but still less than 55000 (16960, I think)
majenko
#2
Mar 04, 2013, 11:26 am Last Edit: Mar 04, 2013, 11:32 am by majenko Reason: 1
Try forcing an integer size:
#define alt  10000UL
That will define "alt" as being an unsigned long value of 10,000.
This is why it is generally better to use "const" for numeric values instead of #define as you specify a data type for the compiler to work with:
const unsigned long alt = 10000;
AWOL
Personal Message (Online)
Re: How does define work?
« Reply #2 on: Today at 11:26:34 »
   Bigger Bigger Smaller Smaller Reset Reset Reply with quoteQuote Modify messageModify Remove messageRemove Split TopicSplit Topic
#define alt  10000UL
const unsigned long alt 10000;
But slip in an assignment, to keep the compiler happy.
majenko
Quote from: Majenko
I haven't finished my first coffee of the day yet.
GekoCH
wow thx a lot
so const is similair to define you still can't change the value after it is "defined" in the code?
Andy
majenko
wow thx a lot
Andy
That is correct.  Once compiled the end result is the same - the number is just a number stored in progmem in the same way as #define - the resultant code is (usually) exactly the same.
PaulS
Vaguely similar. The advantage, as you've seen is that the value part has a type associated with it, unlike the value part of a #define statement. That type lets the compiler point out more mistakes you might make, and lets the compiler generate correct code when the code to be generated depends on the type (as in math operations).
GekoCH
thx a lot to all of you explaining me the problem and the difference among the const and define statement!!!
Andy
