Author Topic: Help needed on using Arduino mega UART (Tx/Rx)  (Read 477 times)
Singapore
Hi, anyone can help me on how to use the Tx/Rx on the Arduino mega.
I am connecting a vga camera to the Tx/Rx pin and intend to get it to take a photo whenever a button which is connected to the Arduino is pushed.
I am thinking of saving the photo file in the SD slot provided by the Arduino ethernet shield.
Thanks
Seattle, WA USA
Seattle, WA USA
Your vga camera came in a plain white box labeled "vga camera"? Or, did it come from a manufacturer with a name and a model number?
And your code looks like?
Singapore
Hi, thanks for your reply.
I am using uCam serial TTL JPEG camera module.
I do not have my code yet as I could not sync the camera which requires me to send a hex command "AAh 0Dh 00h 00h 00h 00h" and receive an ack "AAh 0Eh 0Dh xx 00h 00h.
I am quite a beginner with the arduino programming, please help...
Seattle, WA USA
Seattle, WA USA
I clicked all the links in your reply. Nothing happened.
I looked at your code. It looks pretty skimpy to me.
Singapore
I am quite sloppy with my programming..my basic startup looks something like this:
My camera is connected to the Rx0 and Tx0, 3.3V and Gnd of the arduino.
String Sync = "AA 0D 00 00 00 00";
String Ack;
void setup(){
 Serial.begin(14400);    // Sets the data rate at 14400 baud, camera baud rate minimum 14400
void loop(){
  Serial.write(Sync);      //Send sync command to camera
  delay(5000);             // Wait 5 secs
  Serial.println(Ack);      // Read acknowledge from camera
Seattle, WA USA
Seattle, WA USA
Where did you get the idea that the camera wants a String?
Do yourself a huge favor, and forget that the String class exists.
It is HIGHLY unlikely that the camera responds to a bunch of characters, whether in a String or a string.
It is far more likely that the camera expects a collection of bytes, containing 0xAA, 0x0D, 0x00, etc.
Singapore
Hi, sorry for my poor grasps in the programming field...
I am using the codes below however I am still unable to receive any reply from the camera... Can you advise me?
#include <SoftwareSerial.h>
#define CMD_SIZE 6
SoftwareSerial camera(10, 11); // RX - Mega limits RX pin, TX
static const byte CMD_PREFIX = 0xAA;
static const byte CMD_SYNC = 0x0D;
static const byte CMD_ACK = 0x0E;
byte _command[CMD_SIZE];
byte _receive_cmd[CMD_SIZE];
int attempts = 0;
void setup(){
  camera.begin(14400);
  Serial.println(camera.available());
  Serial.println("Starting...");
  delay(10000);
    if(!sync()) {
    Serial.println(" failed");
void loop(){
boolean sync() {
  bool success = false;
  int attempts = 0;
  // manual indicates we might need 60 attempts at syncing
  while(attempts < 60) {
    createCommand(CMD_SYNC, 0x00, 0x00, 0x00, 0x00);
    Serial.println("Command created!");
    sendCommand();
    delay(200);
    receiveReply();
    if(_receive_cmd[1] == CMD_ACK && _receive_cmd[2] == CMD_SYNC) {
      receiveReply();
      if(_receive_cmd[1] == CMD_SYNC) {
        camera.flush();
        createCommand(CMD_ACK, CMD_SYNC, 0x00, 0x00, 0x00);
        sendCommand();
        return true;
      else {
        return false;
    attempts++;
  return success;
void createCommand(byte cmd, byte param1, byte param2, byte param3, byte param4 ) {
  _command[0] = CMD_PREFIX;
  _command[1] = cmd;
  _command[2] = param1;
  _command[3] = param2;
  _command[4] = param3;
  _command[5] = param4;
void sendCommand() {
  Serial.println("Sending command:");
  for(int i = 0; i < 6; i++) {
      camera.write(_command);
    //camera.print(_command,BYTE);
   Serial.println(_command);
boolean receiveReply() {
  if( camera.available() > 0 )
    for(int i = 0;i < 6; i++) {
      _receive_cmd = camera.read();
    return true;
    Serial.print("Reply is available");
  else {
    return false;
    Serial.print("Reply is not available");
Seattle, WA USA
Seattle, WA USA
If there is at least one byte, read all 6. No, I don't think so, Hal.
