Loading...
Pages: [1]   Go Down
Author Topic: SMPS efficiency calculation  (Read 117 times)
Offline Offline
Newbie
oops
View Profile
Hello !
I build a SMPS driven by arduino (see post http://arduino.cc/forum/index.php?topic=130165) and I would like to calculate the efficiency of my project. Is there a way to easily get this, or, I have to use amp-meter and voltage meter on the output and input of the SMPS ?
I found this related page ! But in that case i need 4 of these devices !
http://www.electronicproducts.com/Power_Products/Power_Management/Avoiding_common_errors_when_designing_an_SMPS.aspx
Can anyone help ?
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
Just measure the power in and the power out and calculate the ratio seems the easiest way.  Otherwise there are losses in several components so it would be pretty hard to calculate them individually and total them.  The inductor has resistive losses, the cap leaks, the diode conducts in reverse for at least some amount of time, everything else at least heats up some so.....
Logged
Experience, it's what you get when you were expecting something else.
Pages: [1]   Go Up
Print
Jump to:
