Topic: [Solved] Help with ATSAM3X8E (Due barebones) (Read 24159 times) previous topic - next topic
zachtos
Hmm, I'm looking to build a barebones board like yours, but from goldphoenix PCB using EAGLEcad and will want to find a way to upload hex files via the native USB port.  So it sounds like I can do that but not sure about the user interface yet.
I need a very simple way for a third party to update via a hex file though, possible w/ the DUE?
IR Combat laser tag developer/inventor
baselsw
Hmmm, wasn't I clear in the previous post? To begin with it's a "bin" file that you upload in this case (not hex).. You can use arduinos "uploader tool" bossac manually, see post #3 in this topic: http://arduino.cc/forum/index.php/topic,153630.0.html.
Another option AGAIN! is to use the SAM-BA program (I said it like a 1000 times already). To download and use SAM-BA go to the following site: http://www.atmel.com/tools/ATMELSAM-BAIN-SYSTEMPROGRAMMER.aspx
zachtos
thanks, I'll install those tools to see how user friendly they are to non engineers that may be using my devices.
michaeluna
Hi baselsw!
I have a question: can you please point to the .bin file that needs to be uploaded to the SAM chip?
Also, I think in your post above you posted an incorrect link by mistake, referring to using Arduino's bossac tool.
I am also making my own Due and am a little stuck on this step. Thank you!
baselsw
Hi baselsw!
There is no bin file that needs to be uploaded.. The Sam-chip will come preloaded with a bootloader.. So it will work out of the box! The link isn't a mistake.. Let me try to explain it in simpler terms:
- In case of uploading (a sketch) to an ordinary AVR (for example the atmega328/UNO) then you'll upload a HEX file with avrdude..
- In case of uploading (a sketch) to a SAM-chip (for example the SAM3X8E/DUE) then you'll upload a BIN file with either BOSSAC or SAM-BA...
- For a newbie I recommend sticking with BOSSAC for uploading because it's simpler.. SAM-BA has a GUI but there is a lot of boxes and settings (a newbie will simply get confused and run back to the arduino forum for help =P)..
If my explanation isn't clear enough then let me know exactly what you're stuck on and I'll do my best to help you!
//Basel
lynxz3
As per baselsw recommendation i'll post this here.
Quote
Hi baselsw,
I was looking at your schematic for the barebones DUE clone, I wanted to confirm something from you,
SV1 headder's pin 1 is pin 1 on atsam3x8e and pin 1on SV2 is pin 37 on the atsam3x8e and so on so forth?
Also i see that in your schematic for VDDCORE and VDDPLL pins on the atsam3x8e you are powering them with 1.8V but i don't see where you are creating the 1.8V. I don't see any resistive divider or any regulated source with that output. Can you tell me how you are creating that source.
Thanks
Taha
Hey Taha,
Yes, pin 1 on SV1 is pin 1 on atsam3x8e, the same goes for SV2, so you're correct there.
The 1.8V is supplied from the internal voltage regulator (pin 56 [VDDOUT]).. You can see how it's connected on page 22 in the atsam3x8e datasheet, here is the link: http://www.atmel.com/Images/doc11057.pdf
If you have any more questions feel free to ask. But please use the thread instead, so others can learn also =)..
Best regards
//Basel
lynxz3
baselsw i had another question whats the power consumption like with the barebone circuit?
baselsw
that's a darn good question.. Normally I don't think about power consumption if it's not something that is going to be a 'final product'... I really have no idea.. The circuit is not "current measurement friendly"... If I get some spare time this week, I'll make a workaround and measure the power consumption.. No promises though..
//Basel
lynxz3
Quote
Hi baselsw,
Thanks
Taha
Hey Taha,
Best regards
//Basel
I thought i'd add this here for everyone else SV2 in baselsw's schematic the pin numbers is are incorrectly labled SV2 e.g. Pin1 goes to ATSAM3X8E -  Pin38 (DHSDM) not Pin37. So if anyone uses it as a reference they should be weary of this.
baselsw
#39
Jul 19, 2013, 02:28 am Last Edit: Jul 19, 2013, 02:31 am by baselsw Reason: 1
Just looking at the pins can be confusing.. It's good that you double checked that.. Still the electrical connections in the schematic are correct.. Let's make it easier for everyone.. I found a excel file with the pinout for my board..
jtw11
So, you got this working and you're currently programming the chip over USB?
You mentioned using Atmel Studio, is that with a USB cable, or using a SAM-ICE?
baselsw
Yes... USB only.. I don't have SAM-ICE or any other JTAG module.. Fortunately the chip comes preloaded with a bootloader... I've programmed the chip with Atmel Studio over USB.. It's simple.. Just create a external tool (http://www.atmel.no/webdoc/atmelstudio/atmelstudio.section.csl_qbq_kc.html) in Atmel Studio.. The tool will consist of a call to bossac (just like the Arduino IDE).. If you need further details let me know..
//Basel
jtw11
I'll look into that in the morning, thanks.
When you say you've been programming it from Atmel Studio, what have you been doing code wise? Coding using pure C and not the Arduino libraries etc?
baselsw
Well, I wouldn't call it pure C.. But sure.. C/C++.. No arduino libraries.. In the case of the SAM chip, I'm only using ASF (Atmel Software Framework) in Atmel Studio..
P.S: Arduino IDE uses ASF .. D.S
You're welcome bro =)..
//Basel
jtw11
#44
Aug 02, 2013, 01:40 pm Last Edit: Aug 02, 2013, 10:26 pm by jtw11 Reason: 1
I see - well done again!
EDIT - I've just been playing with Atmel Studio, my Due and SAM-BA trying to get some results. Maybe you can help.
When I open SAM-BA, under 'Select your board' - what did you select, no_board? As when I press connect SAM-BA just disappears but seems to be running in the background according to Windows Task Manager.
